Текущее время: 06 окт 2024, 06:38
darking
Заголовок сообщения: M2N.Можно ли установить процессор athlon 2 ого покаоления? Добавлено: 07 июл 2012, 00:30 |
Зарегистрирован: 15 июн 2011, 22:19 Наличности на руках: 50.15
Сообщения: 19 Откуда: moskwa
Описание платы: Specifications CPU AMD Socket AM2 Athlon64/Athlon64 FX/Athlon64 X2/Sempron Processors AMD Cool 'n' Quiet™ Technology AMD 64 architecture enables simultaneous 32-bit and 64-bit computing AMD Live!™ Ready Chipset NVIDIA nForce 430 MCP System Bus 2000/1600 Memory 4 x DIMM, Max. 8 GB, DDR2 800/667/533 ECC,Non-ECC,Un-buffered Memory Dual Channel memory architecture *When installing total memory of 4GB capacity or more, Windows 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16 slot 2 x PCIe x1 3 x PCI 2.2 Storage 1 xUltraDMA 133/100/66/33 4 xSATA 3 Gb/s ports NVIDIA MediaShield™ RAID Support RAID 0,1,0+1,5,JBOD LAN NVIDIA® nForce® 430 MCP built-in Gigabit MAC with external Attansic PHY Audio ADI 6 -Channel High Definition Audio CODEC S/PDIF out on back I/O port USB 10 USB 2.0 ports Overclocking Features Intelligent overclocking tools - ASUS O.C. Profile: overclocking configuration-sharing tool SFS (Stepless Frequency Selection) - FSB tuning from 200MHz up to 300MHz at 1MHz increment Overclocking Protection - ASUS C.P.R.(CPU Parameter Recall) Special Features ASUS MyLogo ASUS EZ Flash 2 ASUS CrashFree BIOS 3 Q-Connector ASUS Q-Fan 2 ASUS Fanless thermal solution (heatsink) BIOS 4 Mb Flash ROM DMI 2.0 AMI BIOS PnP WfM 2.0 SM BIOS 2.3 ACPI 2.0a Manageability WOL by PME,WOR by PME,Chasis Intrusion,PXE Internal I/O Connectors 3 x USB connectors support additional 6 USB 2.0 ports 1 x Floppy disk drive connector 1 x IDE connector 4 x SATA connectors 1 x CPU Fan connector 1 x Chassis Fan connector 1 x Power Fan connector 1 x S/PDIF Out connector 1 x4-pin ATX 12V Power connector 24 Power connector Front panel audio connector COM connector Chassis Intrusion connector CD/AUX audio in System Panel Back Panel I/O Ports 1 x Parallel 1 x PS/2 Keyboard 1 x PS/2 Mouse 1 x S/PDIF Out 1 x LAN(RJ45) port 4 x USB 2.0/1.1 6 -Channel Audio I/O O/S Compatibility Windows Vista Windows XP Windows 2000 Support Disc Drivers ASUS PC Probe II Anti-virus software (OEM version) ASUS Update NVIDIA MediaShield™ RAID Accessories User's manual x UltraDMA 133/100/66 cable x Floppy disk drive cable x SATA cable SATA power cable I/O Shield 2 in 1 Q-connector Form Factor ATX Form Factor 12inch x8.1inch ( 30.5cm x20.6cm ) Подскажите, есть-ли способы установке более новых процессоров, официально не поддерживаемых,траффика мало, (гуглить не могу)? Заранее благодарен.
_________________ за идеальную технику - радиолампы)
bupc1
Заголовок сообщения: Re: M2N.Можно ли установить процессор athlon 2 ого покаолени Добавлено: 09 июл 2012, 09:28 |
Зарегистрирован: 12 янв 2012, 12:21 Наличности на руках: 1,981.56
Сообщения: 1439 Откуда: Белгород
sergei21 писал(а): если только эксперимент про приживлению биоса от M2N-E к M2N но что получиться ? Ничего не выйдет чипсеты на этих материнках разные.
