Текущее время: 06 окт 2024, 06:38
Часовой пояс: UTC + 4 часа
 Заголовок сообщения: M2N.Можно ли установить процессор athlon 2 ого покаоления?
СообщениеДобавлено: 07 июл 2012, 00:30
Описание платы:
Specifications
CPU AMD Socket AM2 Athlon64/Athlon64 FX/Athlon64 X2/Sempron Processors
AMD Cool 'n' Quiet™ Technology
AMD 64 architecture enables simultaneous 32-bit and 64-bit computing
AMD Live!™ Ready
Chipset NVIDIA nForce 430 MCP
System Bus 2000/1600
Memory 4 x DIMM, Max. 8 GB, DDR2 800/667/533 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*When installing total memory of 4GB capacity or more, Windows 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Expansion Slots 1 x PCIe x16 slot
2 x PCIe x1
3 x PCI 2.2
Storage 1 xUltraDMA 133/100/66/33
4 xSATA 3 Gb/s ports NVIDIA MediaShield™ RAID
Support RAID 0,1,0+1,5,JBOD
LAN NVIDIA® nForce® 430 MCP built-in Gigabit MAC with external Attansic PHY
Audio ADI 6 -Channel High Definition Audio CODEC
S/PDIF out on back I/O port
USB 10 USB 2.0 ports
Overclocking Features Intelligent overclocking tools
- ASUS O.C. Profile: overclocking configuration-sharing tool
SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 300MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
Q-Connector
ASUS Q-Fan 2
ASUS Fanless thermal solution (heatsink)
BIOS 4 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.3
ACPI 2.0a
Manageability WOL by PME,WOR by PME,Chasis Intrusion,PXE
Internal I/O Connectors 3 x USB connectors support additional 6 USB 2.0 ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x CPU Fan connector
1 x Chassis Fan connector
1 x Power Fan connector
1 x S/PDIF Out connector
1 x4-pin ATX 12V Power connector
24 Power connector
Front panel audio connector
COM connector
Chassis Intrusion connector
CD/AUX audio in
System Panel
Back Panel I/O Ports 1 x Parallel
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x S/PDIF Out
1 x LAN(RJ45) port
4 x USB 2.0/1.1
6 -Channel Audio I/O
O/S Compatibility Windows Vista
Windows XP
Windows 2000
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Accessories User's manual
x UltraDMA 133/100/66 cable
x Floppy disk drive cable
x SATA cable
SATA power cable
I/O Shield
2 in 1 Q-connector
Form Factor ATX Form Factor
12inch x8.1inch ( 30.5cm x20.6cm )
Подскажите, есть-ли способы установке более новых процессоров, официально не поддерживаемых,траффика мало, (гуглить не могу)? Заранее благодарен.
за идеальную технику - радиолампы)
 Заголовок сообщения: Re: M2N.Можно ли установить процессор athlon 2 ого покаолени
СообщениеДобавлено: 07 июл 2012, 21:41
http://ru.asus.com/Motherboards/AMD_AM2 ... luxe/#CPUS
хоть название матери точное ?
и какой проц ставить собрался.
во всём виноват маленький электрон
Ремонт Ноутбуков Планшетов в городе Буденновск
+7-962.404-17,02
СообщениеДобавлено: 08 июл 2012, 14:35
http://www.asus.com/Motherboards/AMD_AM2/M2N/#CPUS - вот эта.
ставить хочу вот это http://www.nix.ru/autocatalog/amd/CPU_A ... 89418.html
то, что в суппорт листе нет - знаю.
СообщениеДобавлено: 08 июл 2012, 15:04
Не прокатит.
СообщениеДобавлено: 08 июл 2012, 17:02
Прескорбно. А по каким именно причинам?
СообщениеДобавлено: 08 июл 2012, 19:30
сегодня шил биос от M2N-E так в ней есть поддержка проца .
если только эксперимент про приживлению биоса от M2N-E к M2N
но что получиться ?
+7-962.404-17,02
СообщениеДобавлено: 09 июл 2012, 09:28
но что получиться ?
Ничего не выйдет чипсеты на этих материнках разные.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. N53D (B14N53DA (0207) rev. 2.0) Старт со 2-3-ого раза
TSARIVAN
3108
26 апр 2016, 15:01
TSARIVAN Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Samsung NP355V5X (LA-8863P rev:1.0) Включение со 2-ого раза
в форуме Samsung
evjen2
2826
26 янв 2017, 19:24
evjen2 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Как установить процессор с soccet FM2+ на мат. плату с сокетом FM ?
romaikalyk
25 апр 2019, 17:48
romaikalyk Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Можно ли установить в телефон аккумулятор от другой модели?
BloodRabbit
24 июл 2019, 10:38
psih1432 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. g62-a83er ((pm_a_hpc_s mv_mb_v1) ) можно ли установить 4009 вместо 9001
Exzo-
1201
01 янв 2020, 16:07
Exzo- Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 22
