Текущее время: 08 сен 2024, 07:25
sandro123
Заголовок сообщения: FX706LI (DABKXDMB8F0) no boot, no show video Добавлено: 10 июл 2024, 18:41 |
Зарегистрирован: 08 янв 2011, 20:37 Наличности на руках: 750.67
Сообщения: 279 Откуда: Italy
History: 19V to short, water dmaged.
find PQ1326 to short, if replaced. voltage restored and board start again.
now have this situation: unstable current in standby, floating 0,05V 0,020A if press power key up to 1,6A - 0,005A (first boot) - 1,8A (with RAM) without ram final current is 0,9A now my doubt is the presence of 0.62V on +VCC_GFX. It doesn't seem correct to have this tension or am I wrong?
the measurable signals are there, the bios is read. the Svid bus is active. CPU core voltage stops at 0.8V what else to check? the damage from liquids did not cause visible damage, it was only present on areas without components
thank you for attention
ruv
Заголовок сообщения: Re: FX706LI (DABKXDMB8F0) no boot, no show video Добавлено: 10 июл 2024, 18:56 |
Зарегистрирован: 07 мар 2011, 00:13 Наличности на руках: 1,821.77
Сообщения: 4287 Откуда: N. Novgorod
CPU is bad +VCC_GFX there should be no voltage at start
