Hi. Laptop Brought for problem was showed on Picture. VGA Chipset & Flat Cable & Display LED LCD was changed by Worked one,but is same. BIOS is TRUE. where I must dig? what is main reason of shadowed display?
_________________ Don't give up without the fight.
and555
Заголовок сообщения: Re: K43SD rev 5 (A43S) display Has shadows.
Добавлено: 13 июн 2015, 11:16
Зарегистрирован: 10 апр 2012, 22:42 Наличности на руках: 86.09 Сообщения: 285 Откуда: Indonesia
try other processor.
_________________ لا إله إلا الله محمد رسول الله
P.zonouz
cpu mounted directly on board, and can not be replaced.
desertearch
Добавлено: 13 июн 2015, 21:13
Зарегистрирован: 30 янв 2015, 15:10 Наличности на руках: 6.44 Сообщения: 334 Откуда: West Side
Hi dude. You have to replace CPU,cause such processors very unstable.
_________________ You've only got three choices in life: Give up, give in, or give it all you've got.
andromedax
Добавлено: 13 июн 2015, 21:45
Зарегистрирован: 01 май 2015, 00:34 Наличности на руках: 3.60 Сообщения: 262 Откуда: Alicante, Spain
HDMI behavior is the same?
U89 (hdmi TMDS level shift) coud be overcharging CPU.
s0ulbl4d3
Добавлено: 21 июн 2015, 19:03
Зарегистрирован: 17 июн 2015, 18:47 Наличности на руках: 0.00 Сообщения: 15 Откуда: indonesia
try to put it into the electric oven with 130c and 13 minutes. Sometimes it work !!! .. But before you put it, please replace all of things such as ram, wifi card, procesor, rubbers, plastics that sticky on the mainboard. Wash it with a soap, clean it and put it into the electric oven.
Сейчас этот форум просматривают: am1r98, djemileo, Yandex [BOT] и гости: 28
