Текущее время: 13 ноя 2026, 15:25
MoneyBot
Заголовок сообщения: Asus X541UV (windows) It does not turn on [РЕШЕНО] |
MoneyBot
Котеус
Заголовок сообщения: Re: Asus X541UV (windows) It does not turn on  Добавлено: 17 ноя 2018, 07:28 |
| Продвинутый форумчанин |
Зарегистрирован: 19 янв 2016, 09:24 Наличности на руках: 1,224.55
Сообщения: 854 Откуда: Eversong
hey! 1. Why you change charger? maybe bad soldering? 2. Please write the model of IC.
Котеус
Заголовок сообщения: Re: Asus X541UV (windows) It does not turn on  Добавлено: 18 ноя 2018, 07:59 |
vasagob писал(а): the dog ate the cable bad dog! :D 1. How many resistance between 1 and 2 lamel, and between ground and 1 lamel? (ACN/ACP) It seems that you have short circuit at AC_BAT_SYS There is a boardview for this motherboard, free in internet. use it. Check resistance at AC_BAT_SYS first.
vasagob
Заголовок сообщения: Re: Asus X541UV (windows) It does not turn on  Добавлено: 19 ноя 2018, 18:32 |
| Интересующийся |
Сообщения: 58 Откуда: Chile
Solved, I found a scheme and I found the the responsible ic was pq8902 please administrator close and thanks for the help
Котеус
Заголовок сообщения: Re: Asus X541UV (windows) It does not turn on  Добавлено: 20 ноя 2018, 11:17 |
You can close theme by yourself, click on green symbol at up-right angle of your "solved" message. AND READ TERMS OF USE, it was written in it.
