Текущее время: 26 июн 2024, 13:59
andromedax
Заголовок сообщения: Re: Asus (n551jk rev2.0) No lcd, no hdmi video output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 24 ноя 2019, 15:13 |
Зарегистрирован: 01 май 2015, 00:34 Наличности на руках: 3.60 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 262 Откуда: Alicante, Spain
andromedax писал(а): Already tet with a new bios dump. Typing error: Already test with a new bios dump. Цитата: All main voltages present, but there is not data communication with lcd panel. (no EDP_AUXP, and no EDP_AUXN) This two signals come from cpu to lcd panel, so cpu dead? It seems to me a little rare, shouldn't it be generated by PCH or GPU? CPU is not dead, as long the laptop loads the operative system. (it can load linux from usb also) This mobo is a nightmare. Where can I dig?
![](images/spacer.gif) |
andromedax
Заголовок сообщения: Re: Asus (n551jk rev2.0) No lcd, no hdmi video output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 24 ноя 2019, 23:25 |
Ciber SLasH писал(а): Look POST code. Post code seems to be normal as you can see in this photo. Вложение: POST.PNG It stops in code AFh while loading linux. Is there any chance to convert to UMA? Thanks.
andromedax
Заголовок сообщения: Re: Asus (n551jk rev2.0) No lcd, no hdmi video output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 25 ноя 2019, 20:37 |
andromedax писал(а): (no lcd, no hdmi video output) Some good news, it has video output trough display port. As you can see in the screenshot, only intel hd graphics is active: Вложение: Clipboard01.jpg
andromedax
Заголовок сообщения: Re: Asus (n551jk rev2.0) No lcd, no hdmi video output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 26 ноя 2019, 21:11 |
andromedax писал(а): Some good news, it has video output trough display port. I'm still working on this board but can not get any information to convert it to uma. (but trough display port it works only with intel graphics) I want to get a bios with discrete gpu disabled, or modified the bios with amibcp, but it give an error "it is not an aptio v" Can someone indicate where to download amibcp ver. 4.53? Thanks. Вложение: amibcp.PNG
andromedax
Заголовок сообщения: Re: Asus (n551jk rev2.0) No lcd, no hdmi video output ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 27 ноя 2019, 19:57 |
andromedax писал(а): Can someone indicate where to download amibcp ver. 4.53? Hi, a friend give me a copy of amibcp 4.53 and now I can modify bios dump. I have modified the value of Graphics Configuration, Primary Display, from "SG" to "IGFX". ( to force intel graphics) Laptop works as before, only display port is working. (no lcd panel, no hdmi) Next item to be modified is "iGPU Port Configuration", now is in "Disabled" state. Can someone tell me the items to be modified?. (its a boring work) Вложение: ASUS-NotebookSKU.PNG
