Текущее время: 14 ноя 2026, 12:41
 Заголовок сообщения: Asus (n551jk rev2.0) No lcd, no hdmi video output
СообщениеДобавлено: 22 ноя 2019, 12:55
Hi, trying to repair an Asus n551jk rev2.0 (no lcd, no hdmi video output)
Already tet with a new bios dump.
All main voltages present, but there is not data communication with lcd panel. (no EDP_AUXP, and no EDP_AUXN)
I'm trying to convert to uma with PCB_ID0 and PCB_ID1 resistors but no success. (have no information about uma conversion)
Can anybody help with this board?
 Заголовок сообщения: Re: Asus (n551jk rev2.0) No lcd, no hdmi video output
СообщениеДобавлено: 24 ноя 2019, 14:13
Typing error: Already test with a new bios dump.
This two signals come from cpu to lcd panel, so cpu dead?
It seems to me a little rare, shouldn't it be generated by PCH or GPU?
CPU is not dead, as long the laptop loads the operative system. (it can load linux from usb also)
This mobo is a nightmare.
Where can I dig?
СообщениеДобавлено: 24 ноя 2019, 15:55
Look POST code.
СообщениеДобавлено: 24 ноя 2019, 22:25
Ciber SLasH писал(а):
Look POST code.
Post code seems to be normal as you can see in this photo.
It stops in code AFh while loading linux.
Is there any chance to convert to UMA?
Thanks.
СообщениеДобавлено: 25 ноя 2019, 19:37
Some good news, it has video output trough display port.
As you can see in the screenshot, only intel hd graphics is active:
СообщениеДобавлено: 26 ноя 2019, 20:11
I'm still working on this board but can not get any information to convert it to uma. (but trough display port it works only with intel graphics)
I want to get a bios with discrete gpu disabled, or modified the bios with amibcp, but it give an error "it is not an aptio v"
Can someone indicate where to download amibcp ver. 4.53?
Thanks.
СообщениеДобавлено: 27 ноя 2019, 18:57
Hi, a friend give me a copy of amibcp 4.53 and now I can modify bios dump.
I have modified the value of Graphics Configuration, Primary Display, from "SG" to "IGFX". ( to force intel graphics)
Laptop works as before, only display port is working. (no lcd panel, no hdmi)
Next item to be modified is "iGPU Port Configuration", now is in "Disabled" state.
Can someone tell me the items to be modified?. (its a boring work)
В этой теме нет новых непрочитанных сообщений. Asus n551jk (Asus n551jk) post not completed
andromedax
13 июл 2021, 19:00
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Pavillion DV7 (DAUT1AMB6D0 REV:D) No hdmi, vga or lcd screen output
andromedax
25 май 2017, 02:22
desska Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX 770 2gb MSI WORK pc remote and no video output.
PT-AH
07 дек 2021, 18:44
PT-AH Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. acer (la-5912p rev: 1.0) no video in lcd , video external monitor only
eletmoraes
12 июл 2019, 07:13
eletmoraes Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP DV6 (Quanta R12) hdmi no output
andromedax
2507
30 сен 2018, 17:51
Сейчас этот форум просматривают: DeniTrexo, devil_666_, Oleg8 и гости: 116
