Текущее время: 29 май 2024, 14:36
f-bone
Заголовок сообщения: Dell Latitude E6330 ( LA-7741P) no 19V with PSU Добавлено: 08 июн 2021, 11:32 |
Сообщения: 32 Откуда: Athens - Greece
Hi friends, I have this E6330 that when you connect the original Dell charger the BLUE light on the charger turns off. I replaced the DC jack because it had problems but also the motherboard seems to have issue: 1) there is NO short at 19V, if I inject voltage at PL3 (19V) I see voltages everywhere 3.3V, 5V always are ok. 2) I replaced PU801, PQ2 and input mosfets PQ4, PQ27 (they were ok but just incase of mulfunction) 3) I removed PU1 but still the same, the charger blue light turns off 4) If I use HP charger (no turn off) I can only measure 4V at PQ27.. Photo of blue light: https://drive.google.com/file/d/1sSs2nJ ... sp=sharingAny ideas please?
