Текущее время: 25 ноя 2026, 15:19
 Заголовок сообщения: Dell Latitude E6330 ( LA-7741P) no 19V with PSU
СообщениеДобавлено: 08 июн 2021, 10:32
Hi friends,
I have this E6330 that when you connect the original Dell charger the BLUE light on the charger turns off.
I replaced the DC jack because it had problems but also the motherboard seems to have issue:
1) there is NO short at 19V, if I inject voltage at PL3 (19V) I see voltages everywhere 3.3V, 5V always are ok.
2) I replaced PU801, PQ2 and input mosfets PQ4, PQ27 (they were ok but just incase of mulfunction)
3) I removed PU1 but still the same, the charger blue light turns off
4) If I use HP charger (no turn off) I can only measure 4V at PQ27..
Photo of blue light: https://drive.google.com/file/d/1sSs2nJ ... sp=sharing
Any ideas please?
 Заголовок сообщения: Re: Dell Latitude E6330 ( LA-7741P) no 19V with PSU
СообщениеДобавлено: 09 июн 2021, 10:30
The blue light turns off because there is a problem with the motherboard (if the power supply is definitely working properly). Probably there is a short circuit on the board and the power supply goes into protection mode. Check the resistance on all large coils on the board, you need to find a short circuit.
VERTYANOV_JIG ver. 3.3; ESR-micro v5.0S; XGecu T56, TL866II Plus; Hantek DSO5102P; ACCTA 301; UNI-T UT139C; Zhaoxin RPS-305D
СообщениеДобавлено: 09 июн 2021, 11:05
hi! thank you for your input.
When I inject 19V at PL3 (DC input coil) from lab-PSU the motherboard turns on and works OK.
СообщениеДобавлено: 09 июн 2021, 11:51
Chek the dc-jack and all ceramic capacitors at the input for a short circuit.
СообщениеДобавлено: 10 июн 2021, 17:59
Thank you Oleh, when I inject voltage at pin1 of PL3 with bench PSU the motherboard works! ---> No shorts.. I do not know what is going on here...
СообщениеДобавлено: 11 июн 2021, 08:47
It's good, but it will not work properly without "NB_PSID" (Middle pin of power supply connector, The battery will not charge, problems with processor frequencies...).
СообщениеДобавлено: 11 июн 2021, 14:14
yes I know :(
any ideas why it works with 19V injection but NOT with charger (charger goes to protection mode)?
СообщениеДобавлено: 14 июн 2021, 10:25
Try removing the choke PL2 from the board (for a test) and turn on the board without it. And if possible, change the dc-jack for a new.
СообщениеДобавлено: 14 июн 2021, 11:18
f-bone, my stupid question: have you tried another PSU? :du_ma_et:
СообщениеДобавлено: 17 июн 2021, 14:02
yes I tried 2 PSUs (there are no stupid questions from smart people!)... also I removed the PL2 but again goes in protection mode (see video: https://share.icloud.com/photos/0EvFsJs ... Q#Melissia)
If I put 19V on wire at PL3 (video) the laptop works (photo: https://share.icloud.com/photos/0SMhUsJ ... g#Melissia)
I think the science will give up now :(
СообщениеДобавлено: 17 июн 2021, 14:56
You have a short circuit on the board (in front of the PL3 choke, right after the connector socket), or the DC-JACK(connector with wire) is faulty. Therefore, the power supply goes into protection.
СообщениеДобавлено: 20 июн 2021, 16:08
Check resistance to ground at the pins of the DC connector (motherboard DC connector side - PJPDC1).
Doctrina est fructus dulcis, radicis amarae.
В этой теме нет новых непрочитанных сообщений. Dell Latitude E6330 (La-7741p rev 1.0) Не работают USB порты
в форуме Dell
madiyarmw
06 фев 2020, 14:11
madiyarmw Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Latitude E6330 (QAL70 LA-7741P Rev:1) Не определяет мощность БП
в форуме Dell
Oleh Molinskyi
14
4412
03 апр 2020, 18:47
Oleh Molinskyi Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Latitude E6330 (QAL70 LA-7741P) Не заряжает батарею.
в форуме Dell
maybax
26 июн 2022, 19:13
kestas666 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Latitude E6330 (QAL70 LA-7741P) Не заряжает. при подключении сзу оно уходит в защиту
в форуме Dell
8965
24 сен 2022, 17:50
8965 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell latitude 3440 (dell latitude 3440) Пропадает индексация зарядки
в форуме Dell
LineStar
16 фев 2022, 11:24
Belebirda Перейти к последнему сообщению
Сейчас этот форум просматривают: meht41 и гости: 44
