Текущее время: 21 ноя 2026, 04:25
 Заголовок сообщения: Dell XPS 9300 (LA-H811P) Logo Bootloop
СообщениеДобавлено: 29 ноя 2024, 00:11
I have a Dell XPS 9300.
When i got it, it showed Dell Logo but without Backlight. I replaced USB-C charge IC and a and Gate (SIO_SLP_S3# & RUN_ON_EC = RUN_ON_P).
Now it turns on most of the time (with Backlight) and shows Dell Logo and reboots, i can't enter BIOS. Sometimes it still shows Dell logo without Backlight, if it does this, it has no VCCIN Voltage on CPU. It helps to connect IMVP_VR_ON_EN to external 1V to get CPU Voltage.
On the Board, UC22 Chip heats up to more than 100°C, and it's output VCC1P8A_EN only has around 800mV. UC12 and UC27 also heat up, and the Output Voltage is too low. Should i order and replace those Chips, or is it another Problem?
I don't know where to find a working bios, maybe there is a BIOS issue?
 Заголовок сообщения: Re: Dell XPS 9300 (LA-H811P) Logo Bootloop
СообщениеДобавлено: 02 дек 2024, 05:53
tCoH писал(а):
UC22 Chip heats
What is a chips?
800 mA on 1.8 is unnormaly.
СообщениеДобавлено: 10 дек 2024, 16:58
AOZ1334DI
I replaced four of them on the Board, now the Laptop works (as far as i tested).
СообщениеДобавлено: 10 ноя 2025, 06:06
I've discovered some interesting things to share with you on this model made by Satan himself :de_vil:
I faced this board LA-H811P with no power at all, found a bad type-c connector and a shorted TPS65987DD pd controller, after replacing the connector and removing the dead pd chip I was surprised that this board can give dell's logo with no backlight while vcore = 0v :sh_ok:
Closer inspection reveals tons of dead AOZ1334DI chips so I replaced them all... a dead ALC3281 codec and a bad UC4 (and gate) too...
after replacing them all the board started to work but freezing on dell's logo, I also noticed that the battery isn't charging, first thing I did is flashing the bios but nothing changed...
I've tested tons of bioses with no luck then I built it from the official update but it still freezing on the logo...
all that was done with the board working on a one pd chip, I soldered new second chip and the charging started working but it still freezing...
I've found info somewhere that this board will work only on it's original bios so I put back the original backup but I'm still out of luck..
all that until I turned it on with the battery connected and the devil initialized and started working :wo_ol:
for the sake of experiment I've tested all the bioses I found and the one I made from the update but nothing worked, it freeze on all of them...
So I confirm that:
- this devil will not charge with only one pd controller
- this devil will not initialize without a working battery
- this devil will initialize only on the original bios OR if you're lucky enough to find a pure manufacturer unlocked bios (and I was out of luck with this)
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Доска LA-H811P дял xps 9300\xps 9310 живая
invisible86
11 мар 2026, 13:08
invisible86 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. XPS 13 9300 (LA-H811P) виснет на логоьтпе dell
в форуме Dell
GigaBlyate
3026
28 ноя 2022, 12:20
GigaBlyate Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell XPS 13 9300 (la-h811p ) подсветка
в форуме Dell
pcexpert8
1905
23 сен 2024, 05:23
Lex0505 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XPS P117G (LA-H811P) Странное поведение
в форуме Dell
elektronikas.remonts
20 июн 2024, 15:22
frag5532 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XPS 13 9310 (LA-H811P) висит на делл
в форуме Dell
senseyoo7
11
2896
12 мар 2025, 10:57
ivans Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 39
