Hi guys,
I would like to ask some help for this gpu resurrection:
Palit GTX 1070 DualUnfortunately i can't find correct boardview or schema for this card, only a similar.
The problem is the memory voltage is missing.
I cant find short on the board, the memory line resistance on the L3 inductor is ~70 ohm and the card has Micron memory.
I measured the voltages on the NCP 81278 buck converter.
I tried to change the buck converter for a new one but nothing changed.
Can someone help me where to go?
Thanks in advance.
