Текущее время: 21 ноя 2024, 12:48
User83
Заголовок сообщения: RTX 3070 NO DISPLAY, MODS REPORT HERE Добавлено: 03 сен 2024, 17:31 |
Зарегистрирован: 10 авг 2024, 14:09 Наличности на руках: 10.01
Сообщения: 10 Откуда: ESPAÑA
Hello to everyone,
i have a RTX 3070, recognised in windows, BIOS too, but no dispaly, MODS report below, please help:
MODS arguments :
MODS start: Tue Sep 3 15:25:31 2024
Command Line : gputest.js -skip_rm_state_init
CPU Arch : x86_64 Name : Intel(R) Core(TM) i3-9100 CPU @ 3.60GHz Cores : 4
Version MODS : 455.127
System OperatingSystem: Linux (x86_64) Kernel : 5.9.1-gentoo-x86_64 KernelDriver : 4.00 SBIOS Version : 1.72 SBIOS Date : 11/16/2021 HostName : tinylinux Available RAM : 7518/7918 MB (Free/Size) Sys-uuid : HDD-Serno :
GPU 0 [01:00.0] dev.sub 0.0 ---------------------------------------- DevInst : 0 PCI Location : 0x00, 0x01, 0x00, 0x00 GPU DID : 0x2484 PDI : 0xd26c3f7a2587369b Raw ECID : 0x0040558000000028080631c4 Raw ECID (GHS) : 0x4702808063000000016028080 ECID : SAMSUNG-SA0W6C-22_x5_y2 Device Id : GA104 Revision : a1 Sub Revision : 1 NV Base : 0xde000000 FB Base : 0xc0000000 IRQ : 11
Chipset VID : FFFF (Unknown) Chipset DID : FFFF (Unknown) Chipset ASPM : L0s/L1 Chipset LTR : Enabled
Error 000000000021 : CheckClocks (test 10) script failed to execute [0.000 seconds] Error 000000000021 : Global.RequireGoldenValues script failed to execute [0.039 seconds] Error 000000000021 : Global.LoadGoldenValuesHelper script failed to execute [0.039 seconds] Error 000000000021 : Global.LoadGoldenValues script failed to execute [0.039 seconds] Error 000000000021 : Global.InitializeGpuTests script failed to execute [0.482 seconds] gputest.jse:32: TypeError: subdev.Perf has no properties
Error Code = 000000010021 (script failed to execute)
MODS end : Tue Sep 3 15:25:32 2024 [1.883 seconds (00:00:01.883 h:m:s)]
