Текущее время: 29 ноя 2026, 05:18
 Заголовок сообщения: RTX 3070 NO DISPLAY, MODS REPORT HERE
СообщениеДобавлено: 03 сен 2024, 16:31
Hello to everyone,
i have a RTX 3070, recognised in windows, BIOS too, but no dispaly, MODS report below, please help:
MODS arguments :
MODS start: Tue Sep 3 15:25:31 2024
Command Line : gputest.js -skip_rm_state_init
CPU
Arch : x86_64
Name : Intel(R) Core(TM) i3-9100 CPU @ 3.60GHz
Cores : 4
Version
MODS : 455.127
System
OperatingSystem: Linux (x86_64)
Kernel : 5.9.1-gentoo-x86_64
KernelDriver : 4.00
SBIOS Version : 1.72
SBIOS Date : 11/16/2021
HostName : tinylinux
Available RAM : 7518/7918 MB (Free/Size)
Sys-uuid :
HDD-Serno :
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x2484
PDI : 0xd26c3f7a2587369b
Raw ECID : 0x0040558000000028080631c4
Raw ECID (GHS) : 0x4702808063000000016028080
ECID : SAMSUNG-SA0W6C-22_x5_y2
Device Id : GA104
Revision : a1
Sub Revision : 1
NV Base : 0xde000000
FB Base : 0xc0000000
IRQ : 11
Chipset
VID : FFFF (Unknown)
Chipset DID : FFFF (Unknown)
Chipset ASPM : L0s/L1
Chipset LTR : Enabled
Error 000000000021 : CheckClocks (test 10) script failed to execute [0.000 seconds]
Error 000000000021 : Global.RequireGoldenValues script failed to execute [0.039 seconds]
Error 000000000021 : Global.LoadGoldenValuesHelper script failed to execute [0.039 seconds]
Error 000000000021 : Global.LoadGoldenValues script failed to execute [0.039 seconds]
Error 000000000021 : Global.InitializeGpuTests script failed to execute [0.482 seconds]
gputest.jse:32: TypeError: subdev.Perf has no properties
Error Code = 000000010021 (script failed to execute)
MODS end : Tue Sep 3 15:25:32 2024 [1.883 seconds (00:00:01.883 h:m:s)]
 Заголовок сообщения: Re: RTX 3070 NO DISPLAY, MODS REPORT HERE
СообщениеДобавлено: 03 сен 2024, 17:06
Отчет mats где?
СообщениеДобавлено: 04 сен 2024, 14:32
by the internal graphic card from the mobo
СообщениеДобавлено: 04 сен 2024, 14:40
cd 455.127
./mods gputest.js -oqa -skip_rm_state_init
./mats -e 20 -n 01 -logfile testmats.log
nano testmats.log
СообщениеДобавлено: 04 сен 2024, 16:48
exactly same error:
MODS arguments :
MODS start: Wed Sep 4 15:43:18 2024
Command Line : gputest.js -oqa -skip_rm_state_init
CPU
Arch : x86_64
Cores : 4
Version
MODS : 455.127
System
Kernel : 5.18.1-gentoo-r2-x86_64
KernelDriver : 4.09
Available RAM : 7474/7913 MB (Free/Size)
Sys-uuid :
HDD-Serno :
DevInst : 0
GPU DID : 0x2484
Device Id : GA104
Revision : a1
Sub Revision : 1
IRQ : 11
Chipset
Error 000000000021 : Global.RequireGoldenValues script failed to execute [0.003 seconds]
Error 000000000021 : Global.LoadGoldenValuesHelper script failed to execute [0.004 seconds]
Error 000000000021 : Global.LoadGoldenValues script failed to execute [0.004 seconds]
Error 000000000021 : Global.InitializeGpuTests script failed to execute [0.436 seconds]
MODS end : Wed Sep 4 15:43:19 2024 [1.372 seconds (00:00:01.372 h:m:s)]
СообщениеДобавлено: 04 сен 2024, 17:58
You are showing the mods report, you need the mats report, see the log files.
СообщениеДобавлено: 04 сен 2024, 19:12
Running 455.127 no possible to do MATS: failed to map registered memory... but on 520.175 MATS with 10 MB is PASS.
СообщениеДобавлено: 04 сен 2024, 19:36
There are errors at 20mb or 40mb ?
СообщениеДобавлено: 05 сен 2024, 09:14
no, even 60 mb and no error, bad gpu?
i have made reballing to GPU and i have the next error running MATS on 520.175:
FOUND AN NV DEVICE AT DOMAIN 0 BUS 1 DEVICE 0, BUT ITS MEMORY CYCLE ENABLE BIT IN PCI CONFIGURATION SPACE IS TURNED OFF.
Any idea?
СообщениеДобавлено: 05 сен 2024, 16:11
What error does the video adapter show in Windows Device Manager?
СообщениеДобавлено: 05 сен 2024, 17:22
no errot but not display
СообщениеДобавлено: 05 сен 2024, 18:31
If mods sees it, then the video adapter should be visible in the device manager.
Or after a reball the video adapter is no longer detected? The video chip was not soldered well.
СообщениеДобавлено: 06 сен 2024, 08:43
SOLVED- thanks to everybody DP POWER EN trace was cut, i do not know how, now is fixed and i have video :co_ol:
СообщениеДобавлено: 17 ноя 2024, 16:00
Could you run test after this?
В этой теме нет новых непрочитанных сообщений. NO VIDEO ON RTX 3070 TI, MODS.LOG HERE
User83
28 авг 2024, 12:44
User83 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 3070 and 3070 Ti strange problems
Rorschach315
24
10898
04 мар 2023, 17:56
Roslavl67 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 3070 Mods/mats
bokin021
27 июл 2021, 21:10
В этой теме нет новых непрочитанных сообщений. EVGA RTX 3070 — artifacts / wrong colors only in Windows, MATS and MODS pass, GPU reball did not help
spyke11
19 мар 2026, 17:50
Piglet666 Перейти к последнему сообщению
Сейчас этот форум просматривают: 1985_alex_25 и гости: 105
