Hi to all,
I've got for repair an RTX 2060 Super TURBO 8GB. Is my first time when I deal with this kind of problem.
It passes MATS without any errors. All banks OK. I suspect that is related to the GPU chipset.
I just want to make sure is the chipset since I don't have a BGA rework station (I guess it will be my first investment).
Thanks in advance.
Best regards,
Bogdan DeacPosted after 4 hours 43 minutes:After a closer inspection found that I'm missing two caps on the die. Does anyone know what value they are?
I can take one out and measure it but I just want to do as less work on the die as I can since I don't want to damage it.
The pads are not shorted ... all of them had around 0.15 ohm.
Thanks in advance.
