Текущее время: 19 май 2024, 00:46
 Заголовок сообщения: RTX 2060 Super TURBO 8GB
СообщениеДобавлено: 15 апр 2021, 18:51
Hi to all,
I've got for repair an RTX 2060 Super TURBO 8GB. Is my first time when I deal with this kind of problem.
It passes MATS without any errors. All banks OK. I suspect that is related to the GPU chipset.
I just want to make sure is the chipset since I don't have a BGA rework station (I guess it will be my first investment).
Thanks in advance.
Best regards,
Bogdan Deac
Posted after 4 hours 43 minutes:
After a closer inspection found that I'm missing two caps on the die. Does anyone know what value they are?
I can take one out and measure it but I just want to do as less work on the die as I can since I don't want to damage it.
The pads are not shorted ... all of them had around 0.15 ohm.
Thanks in advance.
 Заголовок сообщения: Re: RTX 2060 Super TURBO 8GB
СообщениеДобавлено: 16 апр 2021, 03:35
viewtopic.php?f=48&t=99855&start=60
aleksros писал(а):
Подлежит обязательной замене память, выпущенная до 49 недели 18 года - micron memory - may be your problem
---------- Добавлено спустя 1 минуту 37 секунд: ----------
Replaceable memory released before week 49 of 18
СообщениеДобавлено: 16 апр 2021, 14:49
It passes MATS test. I can use it as primary card. I've got image in MODS/MATS. If I enter to BIOS or in Windows it displays like that. Found those missing capacitors when inspecting under the microscope. The Chipset was covered in way too much thermal paste and those 2 caps were missing. Will try to put new ones and see if is working. I don't know what value they are.
СообщениеДобавлено: 17 апр 2021, 03:28
what memory is on the card ? mats tests memory at 300 MHz and not at maximum
СообщениеДобавлено: 20 апр 2021, 06:36
Thank you for your reply. Micron MT61K256M32JE-14 BGA Code: D9WCW. After multiple attempts found that on bank is faulty. I will replace it. I didn't know that MATS is running at 300 MHz.
СообщениеДобавлено: 25 апр 2021, 11:11
Is it any way to test the memory with MATS at a higher frequency?
If I run mats ./mats -e 100 I get sometimes errors on FBIOB1. (that's strange... Only sometimes). If I run ./mats -c 1 which takes about 20-30 min. I got errors on all banks FBIOA0-FBIOD1.
В этой теме нет новых непрочитанных сообщений. KVA2 RTX 2060 Super 8GB - Artifacts only without load
klugec
06 фев 2024, 15:07
klugec Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte 2060 Super/2060/1660Ti MODS
madking
2011
05 фев 2023, 07:07
В этой теме нет новых непрочитанных сообщений. Видеокарта ASUS TURBO GeForce RTX 2060 нет питания GPU
kirikl55
2807
22 фев 2023, 21:04
Andrey111112 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus rtx 2060 turbo номиналы резисторов
nemos
25 окт 2020, 22:18
Smoolae Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS RTX 2060 Turbo вентилятор вести себя странно
Smoolae
27 окт 2020, 03:07
Сейчас этот форум просматривают: agsmt, galkinvv, Stormrage и гости: 20
