Текущее время: 29 ноя 2026, 16:26
 Страница 1 из 1 [ Сообщений: 12 ]
 Заголовок сообщения: XFX Rx 470 8GB Stuck at 300Mhz @ 160W Power Draw Idle
СообщениеДобавлено: 01 фев 2023, 07:23
Hello everyone again. I have XFX RX 470 8GB whose memory and core frequency are stuck on 300Mhz and do not change at all. I have checked in GPU-Z and it shows that Power Draw is 150-160 Watts on IDLE. What IC is responsible for measuring the power draw of the chip? I have measured every single resistor near NCP81022 and everything looked fine just like the donor motherboard. I have even changed the NCP81022 but the problem is still the same. Did anyone experience such problem? Please let me know. Thanks
 Заголовок сообщения: Re: XFX Rx 470 8GB Stuck at 300Mhz @ 160W Power Draw Idle
СообщениеДобавлено: 02 фев 2023, 07:28
Anyone???????
СообщениеДобавлено: 04 фев 2023, 22:39
Check 81022 monitoring in HWinfo64, try another VBIOS
This is screen from XFX570 4gb, the minimal column is values at idle mode
Вложение:
СообщениеДобавлено: 07 фев 2023, 07:11
Thanks for the response. The problem is that I have changed NCP81022 as well but still no luck. I have also checked all surrounding resistors, even back side of the gpu. But no luck. I am out of clues.
СообщениеДобавлено: 08 фев 2023, 04:48
The hwinfo can be used for some problem localization
Does the lower pane of hwinfo which directly accesses NCP81022 bypassing driver calculation shows the high power at idle for your card?
If not - the problem lies somewhere in the driver or BIOS, not in the NCP81022 itself.
Otherwize, the problem is tghtly related to NCP81022.
СообщениеДобавлено: 10 фев 2023, 14:11
между выводами ILIM и CSCOMP микросхемы подключен резистор. NCP81022, проверьте его сопротивление
СообщениеДобавлено: 16 фев 2023, 20:51
Hello I have flashed VBIOS from internet . Now the GPU is boosting memory but not VCORE. only sometimes It boosts but it is lagging alot. I have noticed one thing that it is stuck at PCIE @ 16x 1.1 . I have checked all the capacitors behind and front of the PCIE lane all are looking fine no short nothing. What could be the reason ? . I am attaching pictures of HW Info and GPU-Z.
Вложение:
Вложение:
I have attached the picture above.
I have checked that as well it is totally fine. I have compared all the values with donor board all are same. I am out of guess.
СообщениеДобавлено: 16 фев 2023, 21:34
Ну вы блин даёте :-)
Такое вроде даже ВладиСлавик выкладывал :-)
https://www.youtube.com/watch?v=xCZ4BYZm73w
Биос:
https://www.youtube.com/watch?v=wzJlW86jFe8
И т.д. короче питание.
Если самому соображалки не хватает, запрос в ютьюбе навроде: занижена частота ремонт видеокарты.
现在的也越来越难修啊,生意真是不好做啊!
© Конфуций из Шэньчжэня
СообщениеДобавлено: 16 фев 2023, 22:37
The second one thing: "GPU Core Current" stuck at 205.195A
СообщениеДобавлено: 17 фев 2023, 09:20
com77 писал(а):
Well, you give a pancake
This seems to be even VladiSlavik laid out https://www.youtube.com/watch?v=xCZ4BYZm73w Bios: https://www.youtube.com/watch?v=wzJlW86jFe8 Etc. short food . If the mind itself is not enough, the request in YouTube looks like: the frequency of video card repair is underestimated.
Actually I have repaired many gpus with INA3221 problem but in AMD, according to my understanding there is no other IC which checks voltage etc other than NCP81022. I have checked every single resistor near this IC and all are normal. The power draw now rises and decrease but the core clock is not stable at all. I have never seen such case before so I dont know whats wrong with it and where to look since it does not have boardview.
Yes that as well. I will try to check the card again this weekend and update here if I get any success.
СообщениеДобавлено: 17 фев 2023, 12:14
ll_r1d0_ll
I gave an example by analogy. The reason is the same, the implementation is different. Are the all phases working? PLL?
СообщениеДобавлено: 16 мар 2023, 07:26
I have checked everything again and again. Everything is working fine. All phases are fine. I have installed 20+ Bios but all of them have same problem of Power usage showing abnormal on idle. I have changed the Resistor which is between inductors of phases. Even changed the 30K Ohm resistor next to NCP81022 to higher but that also did not help. I have started to give up on this card now. :za_da_va_la:
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Xfx 470 8gb - bios problem (clock 0 memory 0)
alynut991
09 дек 2021, 17:29
Sa1FeR Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Xfx 470 8gb - bios problem (clock 0 memory 0)
alynut991
28
7785
16 фев 2022, 12:59
Pandemonium6 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. XFX 470 8GB Что это за элемент?
Pandemonium6
26 янв 2022, 15:31
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. xfx 470 8GB - no mining, no gpu temp
xDreamcore
18 апр 2022, 21:52
xDreamcore Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Xfx RX5700 - wohnt detect from System, stuck in BIOS POSTUP
Assassin
29 мар 2021, 04:18
EYES Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 144
