Raptor_3000 писал(а):
(PWROK) of the GPU NCP81022. Without this signal, the +VDDCI and +VDDC voltages rose but were static at 0.92 volts
it's called bootup voltage. if there was no PWROK, then there is no SVI2 transition to other voltage levels
different case: gate driver on VDDCI burned, but there is still 0.87V - in this case there was no switching, voltage is present but not enough power for proper operation. so it comes with code 43 too
