Текущее время: 23 май 2024, 06:28
krugliy
Заголовок сообщения: Re: A1465 (820-3208) Тормозит после залития Добавлено: 08 фев 2018, 12:15 |
Зарегистрирован: 15 мар 2011, 08:21 Наличности на руках: 11.43
Сообщения: 285 Откуда: Новосибирск
Как всегда, не хватает знаний и опыта. При повторном тестировании код 4SNS/1/40000000 THSP больше не появлялся. А второй код 4SNS/1/40000000 TmOP повторяется теперь в обоих режимах тестирования, сюда по информации о расшифровке кодов, кстати, приведу для всех:
The error codes If the tests determine there is an error with your system, they will display an error code similar to the following:
4SNS/1/1/4000000 TL0P-130
The codes may be a bit cryptic, but you can contact Apple Support to see what they mean. As a general reference, here are some of the breakdowns for what the error codes mean, so if you see an error that begins with one of these codes, then it means the specified component listed at the end of the code is not working properly:
4ETH: Ethernet controller 4IRP: Main Logic board 4MLB: Logic board controller 4PRC: Processor 4HDD: Hard disk 4MHD: External disk 4YDC: Video card 4SNS: System sensor 4MOT: Fan motor 4MEM: Memory module 4AIR: AirPort wireless card
In the case of a sensor error (4SNS), to determine what type of sensor is being referenced, check its first letter, which should either be "I" for current, "T" for temperature, or "V" for voltage. Then check the second letter against the following list to see what component it refers to:
A: Ambient air sensor B: Battery C: Central processors (CPU) D: DC (direct current) e: PCI-express slot F: FireWire port G: Graphics processor (GPU) H: Hard disk h: Heat pipe (heat sink) L: LCD display M: Memory or memory riser boards m: Misc. (i.e., battery chargers) N: North bridge (motherboard controller) O: Optical drives P: Power bus p: Power supply s: Palm rests for laptops W: Airport Wi-Fi card
In the example mentioned above, a sensor called "TL0P-130" is not working properly, which is an LCD temperature sensor in a portable system.
Мой случай m: Misc - т.е. ничего конкретного, поэтому и спрашиваю у опытных apple мастеров ---------- Добавлено спустя 11 минут 53 секунды: ---------- Уточню - ошибка выскакивает при тестировании с отключенной батареей, если тестировать с АКБ (родная мертвая совсем, поэтому пробовал с китайской сомнительного качества) то вылезает один код 4BAT - ругается на батарейку.
Shooter75
Заголовок сообщения: Re: A1465 (820-3208) Тормозит после залития Добавлено: 08 фев 2018, 12:51 |
Зарегистрирован: 23 фев 2011, 12:57 Наличности на руках: 2,195.34
Сообщения: 2200 Откуда: Chisinau, Moldova
krugliy писал(а): А второй код 4SNS/1/40000000 TmOP повторяется теперь в обоих режимах тестирования Так а что Вы хотите от "тестера", если АКБ отсутствует и датчик он просто не обнаруживает? А на китайскую ругается, потому что сигнатура не из допустимого диапазона, что тоже логично. С оригинальной мертвой АКБ платформа вообще отказывается запускаться? Если есть возможность одолжить оригинальную живую АКБ, проверьте тормоза в такой комплектации.
krugliy
Заголовок сообщения: Re: A1465 (820-3208) Тормозит после залития Добавлено: 08 фев 2018, 13:05 |
В том то и дело что не где такую взять, apple не часто носят даже в другие сервисы, а 11" еще более редкая модель, в подобной теме viewtopic.php?f=51&t=48217 мне ответили что на 3208 еще не тормозят без АКБ. ---------- Добавлено спустя 1 минуту 16 секунд: ---------- В родной АКБ умер контроллер и она не видится устройством.
Shooter75
Заголовок сообщения: Re: A1465 (820-3208) Тормозит после залития Добавлено: 16 фев 2018, 11:30 |
andriyd1 писал(а): часто коррозия под SMC провоцирует такое поведение. если есть следы залития прогрейте Включите содержимое черепной коробки. Вы отдаете себе отчет в том, что Вы советуете человеку? "Прогреть потенциально кородирующий МК". Откуда вы лезете такие? То ТС:А родной АКБ умер не от этой же воды случайно? Может по SMBus подгнило что-то мелкое, там есть и пулапы и esd защита по цепи обмена с АКБ-чарджером. Тогда и бата видеться не будет, и датчик Т в АКБ не ответит, и тормоза вполне нормальны. Если ASD матюгнулся всего лишь на 4SNS/Misc - кроме АКБ и SSD - больше никто под этот шаблон не попадает. Чаще всего тормоза из-за незнания SMC тока потребления платформой. Этот датчик опрашивается чарджером, без этой инфы - процу не разрешается поднять частоту до требуемой и не будет заряда АКБ. Но раз у Вас в ASD не возникло I*** ошибок , проверьте цепь smbus от SMC до чарджера и до АКБ, лучше осциллографом и омметром. И еще, надеюсь, у Вас хватит интуиции SMC не "прогреть", а зареболлить, при подозрениях на коррозию под ним?
