Текущее время: 14 ноя 2024, 10:31
 Заголовок сообщения: MacBook Pro 13" a1278 ремонта
СообщениеДобавлено: 01 мар 2013, 02:44
Привет всем. Им с помощью Google Translate для перевода с английского на русский.
У меня есть неисправный MacBook Pro 13 "A1278. Аэропорт Trackpad и Ethernet порт не работает. Я купил новый трекпад и он по-прежнему не работает. Кто-нибудь имеет никакого понятия, как исправить? Есть ли неисправный компонент на логику платы, которая прошла плохо?
С уважением
 Заголовок сообщения: Re: MacBook Pro 13" a1278 ремонта
СообщениеДобавлено: 01 мар 2013, 08:38
Write in english. Real engineers knows english.
I think You have the trouble with ethernet chip first.
USB is working? All other devices?
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 01 мар 2013, 10:44
Thanks!
Yes all usb are working. The trackpad was working but it has now stopped. The camera works but if the airport card is connected, the macbook wont boot up.
Where to find this chip? I know if a device on a mac is not working then few others may not work because of it.
СообщениеДобавлено: 01 мар 2013, 11:29
When install the new and old airport card - same defect?
You wrote -Ethernet (i.e. LAN, i.e. cable connection) not working too. Is it correct?
СообщениеДобавлено: 01 мар 2013, 11:58
There is a ribbon that attaches the camera and airport card. If I attach that ribbon to the logic board, the laptop wont boot up: stays on white screen (no apple logo no nothing). If the airport card is removed all is ok. So while the airport card not is not connected, the camera works great. If change airport card with a known working one, same result.
Ethernet (LAN) does not work. Shows not installed.
СообщениеДобавлено: 01 мар 2013, 12:46
AirPort and Ethernet connected via PCI bus. Perhaps you have defective (burning) Ethernet chip and he block other devices like AirPort and TrackPad.
If PCI bus not working or works incorrectly it usually means that faulty Northbridge.
You must have special equipment like BGA rework station and special skills to replace Northbridge.
Try to "Reset SMC" first - may be it's helps You.
СообщениеДобавлено: 01 мар 2013, 16:07
Thanks. Where to find that Northbridge? I have tools for any jobs
СообщениеДобавлено: 01 мар 2013, 16:24
PERHAPS NorthBridge. If You have tools - You must have the advanced diagnostics skill first. My online diagnosis is only assumptions.
СообщениеДобавлено: 01 мар 2013, 17:28
yes but where is that Northbridge chip?
СообщениеДобавлено: 02 мар 2013, 09:28
Tell first system board platform. I think this platform has mcp89mz chip.
СообщениеДобавлено: 02 мар 2013, 10:28
Ok. but how that can be faulty when the laptop works great? I have no other issues apart from what I said.
В этой теме нет новых непрочитанных сообщений. Apple Macbook A1278 (A1278 2010) Где купить USB
в форуме Apple
Andrey1997
22 фев 2022, 23:15
Andrey1997 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. macbook pro (macbook pro) Ремонт разъема БП
в форуме Apple
RavD
9848
20 дек 2015, 04:22
MLife Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro A1286 (820-2330-А) MacBook Pro A1286 нужен damp bios
в форуме Apple
sailenshils
14
12213
12 дек 2016, 18:57
sailenshils Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Macbook Pro A1398 820-3787-A (Macbook Pro A1398 820-3787-A) Замена клавиатуры
в форуме Apple
Bobb
15 июн 2017, 10:49
saponya Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MacBook Pro 15 2013 (A1398) MacBook Pro 15 2013 выключается хаотично, проверьте Дамп!
в форуме Apple
Saip
5548
25 апр 2018, 14:31
Saip Перейти к последнему сообщению
Сейчас этот форум просматривают: Jekep, kiwin и гости: 36
