Текущее время: 14 ноя 2024, 21:13
MSF113
Заголовок сообщения: Re: MacBook Pro 13" a1278 ремонта Добавлено: 01 мар 2013, 08:38 |
Сообщения: 14947 Откуда: Екатеринбург
Write in english. Real engineers knows english. I think You have the trouble with ethernet chip first. USB is working? All other devices?
speedypro
Заголовок сообщения: Re: MacBook Pro 13" a1278 ремонта Добавлено: 01 мар 2013, 10:44 |
Зарегистрирован: 01 мар 2013, 02:36 Наличности на руках: 26.02
Сообщения: 10 Откуда: United Kingdom
MSF113 писал(а): Write in english. Real engineers knows english. I think You have the trouble with ethernet chip first. USB is working? All other devices? Thanks! Yes all usb are working. The trackpad was working but it has now stopped. The camera works but if the airport card is connected, the macbook wont boot up. Where to find this chip? I know if a device on a mac is not working then few others may not work because of it.
MSF113
Заголовок сообщения: Re: MacBook Pro 13" a1278 ремонта Добавлено: 01 мар 2013, 11:29 |
When install the new and old airport card - same defect? You wrote -Ethernet (i.e. LAN, i.e. cable connection) not working too. Is it correct?
speedypro
Заголовок сообщения: Re: MacBook Pro 13" a1278 ремонта Добавлено: 01 мар 2013, 11:58 |
MSF113 писал(а): When install the new and old airport card - same defect? You wrote -Ethernet (i.e. LAN, i.e. cable connection) not working too. Is it correct? There is a ribbon that attaches the camera and airport card. If I attach that ribbon to the logic board, the laptop wont boot up: stays on white screen (no apple logo no nothing). If the airport card is removed all is ok. So while the airport card not is not connected, the camera works great. If change airport card with a known working one, same result. Ethernet (LAN) does not work. Shows not installed.
MSF113
Заголовок сообщения: Re: MacBook Pro 13" a1278 ремонта Добавлено: 01 мар 2013, 12:46 |
AirPort and Ethernet connected via PCI bus. Perhaps you have defective (burning) Ethernet chip and he block other devices like AirPort and TrackPad. If PCI bus not working or works incorrectly it usually means that faulty Northbridge. You must have special equipment like BGA rework station and special skills to replace Northbridge.
Try to "Reset SMC" first - may be it's helps You.
MSF113
Заголовок сообщения: Re: MacBook Pro 13" a1278 ремонта Добавлено: 01 мар 2013, 16:24 |
PERHAPS NorthBridge. If You have tools - You must have the advanced diagnostics skill first. My online diagnosis is only assumptions.
MSF113
Заголовок сообщения: Re: MacBook Pro 13" a1278 ремонта Добавлено: 02 мар 2013, 09:28 |
Tell first system board platform. I think this platform has mcp89mz chip.
