Текущее время: 21 ноя 2026, 04:23
 Заголовок сообщения: HP 850 G6 (Crescent-6050A3022501-MB-A01) iGPU sudden Death !!
СообщениеДобавлено: 31 май 2025, 17:11
Hello..
This laptop came with a bad ec chip, I replaced it from a donor board and flashed both main and ec bios and it started.
tried original main & ec dumps and it started on original bios, fully tested and given to the owner..
in 24 hours it came back with 1 caps-lock blink code (CPU failure :sh_ok: ), I've read the bios and ec contents and found differences from the original backup in both chips, tried to flash it with official bios using usb recovery method without success...
unsoldered both chips and flashed them again with the original backup and it started, thought that a failed online bios update caused the problem so I went to setup to disable online update and found this option (update system and supported device firmware using local media) clicked on it to check it out and it started flashing (ssd was on the board) and when finished it turned off, it didn't restart....
I turned it on and it gave 1 caps-lock blink code again, checked the voltages and found that vccgt has 0.66v :ps_ih:
if vccgt has high voltage during initialization that's a sign of a dead igpu, am I correct ?!
it has i5-8365u (SRF9Z) with 3.9 ohms vcore & 5.6 ohms vccgt...
replaced vccgt power & flashed with official bios again to no avail... tried to reflow the whole cpu but no success...
how the hell the igpu went dead on me, or is there 1% chance the problem could be somewhere else ?
I need an answer from the masters please...
В этой теме нет новых непрочитанных сообщений. HP EliteBook 850 G6 (Crescent 6050A3022501-MB-A01 (A1)) не включаются
guar33
10
649
05 июн 2026, 19:35
guar33 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP EliteBook 840 G6 (6XE67ET) (CRESCENT-6050A3022501-MB-A01) Помогите опознать элементы
bicmark
29 дек 2020, 15:24
Remzona Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. elitbook 840 G6 (crescent-6050A3022501-MB-A01) Не включается, утеряна прошивка BIOS
Remzona
30 дек 2020, 13:28
В этой теме нет новых непрочитанных сообщений. HP ZBook 14u G6 (CRESCENT-6050A3022501-MB-A01) Собрать BIOS
Chazy-Chaz
21 май 2021, 12:14
Chazy-Chaz Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP EliteBook 840 G6 (CRESCENT-6050A3022501-MB-A01) Помогите снять пароль с BIOS
в форуме Поиск BIOS
MTAMaster
04 янв 2022, 12:53
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 128
