Текущее время: 21 ноя 2026, 03:40
| Автор |
Spongebob89
Заголовок сообщения: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present  Добавлено: 08 фев 2026, 23:42 |
| Интересующийся |
Зарегистрирован: 25 июн 2022, 22:34 Наличности на руках: 209.18
Сообщения: 47 Откуда: Greece
Hello guys, I have the HP 250 G5 laptop and when I press the power button the CPU fan spins for half a second and then nothing. Also, the screen is totally black. 1. I measured the voltage rails 19V, 5V, 3V for a short circuit but I didn't found a short circuit. 2. When I have connected the power supply on the motherboard the voltage rails " +3VALWP" & "+5VALWP" are not present. On the page 46 from the schematic diagram I measure on the " PU2" regulator only the " +3VPL-pin15-3V measured" & " +VLP-pin14-5V measured" are present, but the " ENM-pin13" is 0V. According to Power ON Sequence at page 6 after " +3VPL/+5VPL" the " EC_ON-pin13" goes high, but I always measure it 0V. I pressed the power button after this modification where I done but the laptop didn't start besides the 3V & 5V now are enabled. 3. In order to clarify if the regulator is working I disconnected the "PR51/2.2Kohm" resistor and I connected/soldered the "EC_ON-pin13" direclty to " +VLP-pin14 (5V)" and then I measured 5V at "PL8" inductor and 3V at " PL9" inductor. For some reason the " EC_ON-pin112 - page 27" from the " UK1-KB9022QD" don't go high in order the 3V & 5V will be produced. 4. Do you beleive the " UK1-KB9022QD" has corrupt firmware and needs re-programming or maybe there is something else the problem? 5. I found the attached firmware " 15-BD003TX BDL50 LA-D704P Rev 4.0 KB9022D" on the net but I am not sure if it is the right one. Any suggestions are welcomed. | ! | igils писал(а): | II. General Forum Rules: 10. Upload the schemes and any other files which are already in the forum is forbidden. 12. To attach schemes to the messages is forbidden. For this purpose there is the appropriate theme in each subsection of the specific producer. |
MoneyBot
Заголовок сообщения: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present |
MoneyBot
Заголовок сообщения: Re: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present  Добавлено: 11 фев 2026, 11:56 |
Зарегистрирован: 23 июл 2011, 13:13 Наличности на руках: 15,621.30
Сообщения: 12678 Откуда: Ульяновск
BQ24725 (5pin ACOK) - 19,25V? 19.97V at 4 measured points? I don't believe it.
Заголовок сообщения: Re: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present  Добавлено: 11 фев 2026, 23:51 |
According to page 6, these voltages rise after pressing the button, which is what you observe. Look not only at the list of signals, but also at their generation times.
Заголовок сообщения: Re: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present  Добавлено: 12 фев 2026, 14:19 |
Spongebob89 писал(а): I can't find in the schematic pdf the signals +3VL_RTC & SOC_RTCRST# There is no need to take everything shown in the diagram literally - the developer can transfer pages from one diagram to another without worrying that he named the signals differently there or that they are not there at all. For example, don't look for +3VL_RTC, SOC_RTCRST#, but just RTC, and you'll find everything related to that power supply. If your +3VALW +5VALW and EC_ON=3V power supply appears after pressing the button, this may be correct. Keep checking. And use version 0.1 of the schematic; the Power Sequence is described more accurately there.
Заголовок сообщения: Re: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present  Добавлено: 13 фев 2026, 12:59 |
Measure the resistance between KB9022 and GND: MAIN_ON (104-pin connector) EC_ON (112-pin connector) 3VALW, 5VALW. On a powered board, voltage at ON/OFF# (114-pin connector) LID_SW# (115-pin connector) KB9022. ---------- Добавлено спустя 15 минут 50 секунд: ---------- Spongebob89 писал(а): when I press the power button the CPU fan spins for half a second and then nothing Without 5VALW and 5VS the cooler will not spin at all. But you claim that 3VALW and 5VALW are missing, while your words: Spongebob89 писал(а): I pressed the power button after this modification where I done but the laptop didn't start besides the 3V & 5V now are enabled. You're misleading both yourself and others. Please update this information. If you have any information about the laptop's history or any repairs you've performed on it, please share it.
Заголовок сообщения: Re: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present  Добавлено: 14 фев 2026, 02:16 |
Spongebob89 писал(а): I remove the PQ8... This is pointless, as is measuring the 3VALW and 5VALW resistances immediately after disconnecting the charger. Discharge PC37 and PC38 before measuring. Spongebob89 писал(а): MAIN_ON (104-pin connector) -> 299ohm Is the 104-pin KB9022 (MAINPWON) connected to pin 13 of PU2? Yes -> Try replacing KB9022. After removing KB9022, you need to test the ground connection from pin 104 of the MAINPWON circuit again. If the resistance is high, everything is fine. If not, remove PU2.
Заголовок сообщения: Re: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present  Добавлено: 15 фев 2026, 20:29 |
Spongebob89 писал(а): so maybe the problem is the PU2 (RT8243AZQW)? Perhaps, if you have another RT8243AZQW, install it and repeat the measurements. You can also test the RT8243AZQW without installing the KB9022. Pull it up to LDO3 to enable both switch channels.
