Текущее время: 21 ноя 2026, 03:52
 Заголовок сообщения: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present
СообщениеДобавлено: 08 фев 2026, 23:42
Hello guys, I have the HP 250 G5 laptop and when I press the power button the CPU fan spins for half a second and then nothing. Also, the screen is totally black.
1. I measured the voltage rails 19V, 5V, 3V for a short circuit but I didn't found a short circuit.
2. When I have connected the power supply on the motherboard the voltage rails "+3VALWP" & "+5VALWP" are not present. On the page 46 from the schematic diagram I measure on the "PU2" regulator only the "+3VPL-pin15-3V measured" & "+VLP-pin14-5V measured" are present, but the "ENM-pin13" is 0V. According to Power ON Sequence at page 6 after "+3VPL/+5VPL" the "EC_ON-pin13" goes high, but I always measure it 0V. I pressed the power button after this modification where I done but the laptop didn't start besides the 3V & 5V now are enabled.
3. In order to clarify if the regulator is working I disconnected the "PR51/2.2Kohm" resistor and I connected/soldered the "EC_ON-pin13" direclty to "+VLP-pin14 (5V)" and then I measured 5V at "PL8" inductor and 3V at "PL9" inductor. For some reason the "EC_ON-pin112 - page 27" from the "UK1-KB9022QD" don't go high in order the 3V & 5V will be produced.
4. Do you beleive the "UK1-KB9022QD" has corrupt firmware and needs re-programming or maybe there is something else the problem?
5. I found the attached firmware "15-BD003TX BDL50 LA-D704P Rev 4.0 KB9022D" on the net but I am not sure if it is the right one. Any suggestions are welcomed.
 ! igils писал(а):
II. General Forum Rules:
10. Upload the schemes and any other files which are already in the forum is forbidden.
12. To attach schemes to the messages is forbidden. For this purpose there is the appropriate theme in each subsection of the specific producer.
 Заголовок сообщения: Re: HP 250 G5 (LA-D704P) Not Start - 3VALWP & 5VALWP Not Present
СообщениеДобавлено: 11 фев 2026, 00:14
I use the Xegu T56 programmer and I program the "KB9022D" super IO chip with the firmware (attached in my post one). Before I re-program the KB9022D I read it (attached file in this post "KB9022@LQFP128old") and I use the "Compare It!" software to compare the two firmware and I found "little" differences between them.
The same thing again.
I made also some measurements at "KB9022D" super IO chip and at the "BQ24725" charger chip.
What else can cause the KB9022D not to start (EC pin=0V) produce the 3V & 5V rails?
СообщениеДобавлено: 11 фев 2026, 11:56
Светлая память
Светлая память
BQ24725 (5pin ACOK) - 19,25V?
19.97V at 4 measured points?
I don't believe it.
СообщениеДобавлено: 11 фев 2026, 22:45
You are right. I made a typo mistake.
I measured all the pins from the "BQ24725" charger chip (Attached Image: BQ24725 - Right Measurements). I beleive they seem ok.
>> I took these measurements when battery was disconnected and with all the cables/ribbon cables disconnected from the motherboard (except from the power suuply jack 19V).
What is your opinion about the missing 3V & 5V rails?
Последний раз редактировалось Spongebob89 11 фев 2026, 23:51, всего редактировалось 1 раз.
СообщениеДобавлено: 11 фев 2026, 23:51
Светлая память
Светлая память
According to page 6, these voltages rise after pressing the button, which is what you observe.
Look not only at the list of signals, but also at their generation times.
СообщениеДобавлено: 12 фев 2026, 00:55
Please could you check my attached image?
I can't find in the schematic pdf the signals +3VL_RTC & SOC_RTCRST# & in order to measure their times.
Also, I have a 4 channel oscilloscope. In what combination I have to measure their sequence times between them?
For instance:
CH1: +3VL_RTC
CH2: SOC_RTCRST#
CH3: +19VB
CH4: +5VLP
or
CH1: +3VL_RTC
CH2: SOC_RTCRST#
CH3: +19VB
CH4: +3VLP
or
CH1: SOC_RTCRST#
CH2: +19VB
CH3: +3VLP
CH4: EC_ON
Thanks for your time to reply me.
СообщениеДобавлено: 12 фев 2026, 14:19
Светлая память
Светлая память
There is no need to take everything shown in the diagram literally - the developer can transfer pages from one diagram to another without worrying that he named the signals differently there or that they are not there at all.
For example, don't look for
+3VL_RTC, SOC_RTCRST#, but just RTC, and you'll find everything related to that power supply.
If your +3VALW
+5VALW
and EC_ON=3V power supply appears after pressing the button, this may be correct.
Keep checking.
And use version 0.1 of the schematic; the Power Sequence is described more accurately there.
СообщениеДобавлено: 13 фев 2026, 02:43
I didn't found Rev 0.1. The only I found is Rev 1.0 (Image: Rev1.0 Power ON Sequence) where indeed the Power Sequence is described more accurately.
The rails +3VALW & +5VALW is not always ON... they aren't produced continiously after the power supply is plugged?
I measured the below at the time where I connected the power supply jack on the laptop (Images: When I plug the Power Supply_+3VALW & When I plug the Power Supply_+5VALW).
CH1: +19.5VB_3V/5V
CH2: +3VLP
CH3: EC_ON
CH4: +3VALW
CH1: +19.5VB_3V/5V
CH2: +3VLP
CH3: EC_ON
CH4: +5VALW
I measured the below at the time where I connected the power supply jack on the laptop (Images: When I pressed the Power Button_+3VALW & When I pressed the Power Button_+5VALW).
At this measurements I saw that when I pressed the power button the EC_ON goes high for about 14sec and then goes low, but the high level is 421mV and not 3,3V and also the "+5VALW" rail is completely dead instead of the "+3VALW" rail where has a voltage level 2,25V (not 3,3V which is correct). maybe the problem is on the "+5VALW" rail? What do you beleive?
CH1: +19.5VB_3V/5V
CH2: +3VLP
CH3: EC_ON
CH4: +3VALW
CH1: +19.5VB_3V/5V
CH2: +3VLP
CH3: EC_ON
CH4: +5VALW
I made some measurements with oscilloscope.
СообщениеДобавлено: 13 фев 2026, 12:59
Светлая память
Светлая память
Measure the resistance between KB9022 and GND:
MAIN_ON (104-pin connector)
EC_ON (112-pin connector)
3VALW, 5VALW.
On a powered board, voltage at
ON/OFF# (114-pin connector)
LID_SW# (115-pin connector) KB9022.
---------- Добавлено спустя 15 минут 50 секунд: ----------
Without 5VALW and 5VS the cooler will not spin at all.
But you claim that 3VALW and 5VALW are missing, while your words:
You're misleading both yourself and others.
Please update this information.
If you have any information about the laptop's history or any repairs you've performed on it, please share it.
СообщениеДобавлено: 14 фев 2026, 01:25
Resistance between KB9022 and GND (red lead from the multimeter in GND):
MAIN_ON (104-pin connector) -> 299ohm
EC_ON (112-pin connector) -> 2,44K
3VALW -> If plug the power supply on the motherboard and immediately after remove it I measure 360ohm and this value increases and after 3.17min goes to 0,99K.
5VALW -> If plug the power supply on the motherboard and immediately after remove it I measure 15ohm, but here something "strange" happens... after 5mins the resistance goes to 1K for 1sec and then drops to 300ohm and afrer 1sec goes again to 1K and then drops to 300ohm and the resistance starts to increase again and after 2 mins goes to 1K (this sequence is not the same in time and resistance values as many times as I repeated the procedure).
On a powered board, voltage at KB9022:
ON/OFF# (114-pin connector) -> 3,25V
LID_SW# (115-pin connector) -> 3,27V
I remove the PQ8 to check if this was the problem but when I plug the power supply on the motherboard the 3VALW rail was 0V. When I plug the power supply the 3VALW & 5VALW must be produced independent if I press or not the power button?
When I press the power button (and now where I remove the PQ8) I measure for about 15sec 1,86V at 3VALW rail.
I haven't repair this laptop again and I don't know if any other has repair it before. I take it with this problem.
"when I press the power button the CPU fan spins for half a second and then nothing"
This happened only 1 time... I can't reproduced again.
СообщениеДобавлено: 14 фев 2026, 02:16
Светлая память
Светлая память
I remove the PQ8...
This is pointless, as is measuring the 3VALW and 5VALW resistances immediately after disconnecting the charger. Discharge PC37 and PC38 before measuring.
Is the 104-pin KB9022 (MAINPWON) connected to pin 13 of PU2? Yes -> Try replacing KB9022.
After removing KB9022, you need to test the ground connection from pin 104 of the MAINPWON circuit again. If the resistance is high, everything is fine. If not, remove PU2.
СообщениеДобавлено: 15 фев 2026, 02:00
"Is the 104-pin KB9022 (MAINPWON) connected to pin 13 of PU2? Yes -> Try replacing KB9022."
Between pin-104 KB9022 (MAINPWON) and pin-13 of PU2 (RT8243AZQW) I measured 0ohm.
"After removing KB9022, you need to test the ground connection from pin 104 of the MAINPWON circuit again. If the resistance is high, everything is fine. If not, remove PU2."
After I removed/desoldered the KB9022 (Super I/O chip) I measured 800ohm between pin-104 KB9022 (MAINPWON) and Ground. Is this value acceptable (I beleive is low again for an input pin). Unfrtunately, I don't have right now a new KB9022 available to replace it.
Desoldered from the motherboard both KB9022 & RT8243AZQW:
Between pin-104 (KB9022)/pin-13 (RT8243AZQW) and Ground the resistance was 81,7K, so maybe the problem is the PU2 (RT8243AZQW)?
СообщениеДобавлено: 15 фев 2026, 20:29
Светлая память
Светлая память
Perhaps, if you have another RT8243AZQW, install it and repeat the measurements.
You can also test the RT8243AZQW without installing the KB9022.
Pull it up to LDO3 to enable both switch channels.
СообщениеДобавлено: 08 мар 2026, 16:53
I bought the below RT8243AZQW from Aliexpress.
I soldered it and I gave power 19V to motherboard.
1. I measured on pin11 from RT8243AZQW and the 19V was not present.
I desoldered then the KB9022QD and the 19V was present and also the at pin15 (+3VLP) 3V and at pin14(+VLP) 5V.
2. With the (KB9022QD ) I bridge the pin13(ENM) with pin15 (+3VLP) to check if the 3VALW & 5VALW will produced. Nothing. I measure on PL9 0.1ohm and on PL8 115ohm.
3. I inject 1.6V/4.9A on PL9 to find the short via heat (with 0ohm will be no power loss on the shorted component and the thermal emmition will be very low). I spray isopropyl alcohol every where on PCB but I couldn't track any heat. Only the CPU is getting little hot.
4. On PL8 (5V rail) where I measure 115ohm is normal or I have and here short?
5. Do you beleive something went wrong with the "RT8243AZQW" and burn the KB9022QD and maybe the CPU. How can I track the short on 3V rail?
10pcs RT8243AZQW QFN-20 RT8243A (8A EE,8A EF,8A EC...) new original
В этой теме нет новых непрочитанных сообщений. 250 G5 (LA-D702P) Нет +3VALWP и +5VALWP
Crow
15
2906
24 сен 2021, 11:41
Arlo Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. G580 (QIWG5 LA-7981P rev:1.0) Нет +5VALWP/+3VALWP
pbls
5508
14 июн 2017, 10:11
pbls Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP Compaq NC6220 (6050a0066801-mb-a02) smart card not present
Master-iv37
10 фев 2017, 22:14
Master-iv37 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 250 g5 (la-d704p) Опознать ШИМ
GDI
02 фев 2018, 22:14
GDI Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 250 G5 (BDL50 LA-D704P rev 4.0) Помогите опознать элемент
Pauk
11 апр 2018, 19:35
Pauk Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 107
