Заголовок сообщения: DV9000 (Quanta AT5) works only on an external monitor
Добавлено: 08 окт 2013, 19:13
Зарегистрирован: 12 дек 2012, 15:17 Наличности на руках: 40.00 Сообщения: 5 Откуда: india
Welcome. This is exactly the model dv9780ew zpłytą codenamed DA0AT5MB8E0. Laptop when you turn did not show anything on the sensor, not even turn on the backlight on the external monitor is about podstawił tie to die and nothing, so I warmed graf g86-770-a2 but it also did not change anything, I had a new graphics system so I replaced and remains the same. What else do you see? Thanking you...
arjuk
Заголовок сообщения: Re: DV9000 (Quanta AT5) works only on an external monitor
Сейчас этот форум просматривают: lestat и гости: 16
Реклама
