I want a solution to this problem
This picture of the problem
![Изображение](http://store1.up-00.com/2016-01/14532346064651.jpg)
[url="http://www.up-00.com/"]"http://www.up-00.com/"[/url]
Obviously there is a problem and when the fan letter: Skip f1the machine is working good
I want the amendment to the BIOS file and delete this code in order to not appear
Basic problem that the device works for 10 minutes and separated
When the yellow wire separating and feeding the fan with 5 volt outsourcing works non-stop
With this and there is a message f1
When you follow the line Alsenssor There are no problems
I want to outline for this device or solution scans f1 of Alvallos file code
This is the file good test
http://www.mediafire.com/download/dul5b ... j/t731.rarPlease attention
Wait Replies
