andr-sam.f писал(а):
You have no reaction to the power button?
You can try to power +3VS from a laboratory power supply
Power button is on the same connector that im using for vertyanov programming.
If i short the power_on//off pin then led is turning on on the side but 3VS has only 330mA.
Applying 3V on +3VS with LAB PSU not changed anything :(
I also have 3VALW and 5VALW
