Текущее время: 28 ноя 2026, 02:18
| Автор |
xe_d_sono
Заголовок сообщения: SF40CM (SF40CM v1.1) Keys problem  Добавлено: 17 окт 2026, 14:08 |
| Интересующийся |
Зарегистрирован: 19 янв 2014, 22:37 Наличности на руках: 57.06
Сообщения: 57 Откуда: Portugal
Hello,
I have a Lenovo SF40CM with faulty EC (IT8851-128). It turns on / off and EC is getting very hot (i check its shorted).
Replaced with new one and now, laptop turn on and works very well, exepcted for keyboard.
Keys like HOME, DEL, END, PAGUP and PGDOWN have strange beaver: when pressed it send a combination of commands, or letters. Ex: when presse home it print something like "1324798", and when it was pressed again it give "1324799".
I try to replace EC again and same problem.
I try clean windows install, live windows, diferent so same problem.
With SVOD i detect all this keys are the same line, 9 pin.
I replace the capacitor filter (just for sure!) on that line, cheking for short, but nothing.
I try to program EC with SVOD but i cannot estrablish connection (yes, i used for all other IT and it works), its possible to program this EC with this model of SVOD?
What it could be?
Thanks.
Edit: i try other keyboard, and same problem.
MoneyBot
Заголовок сообщения: SF40CM (SF40CM v1.1) Keys problem |
