Текущее время: 05 июн 2024, 05:56
frankmnld
Заголовок сообщения: Acer E1-572 (LA-9532P) Black screen Добавлено: 26 дек 2020, 01:09 |
Зарегистрирован: 18 ноя 2020, 21:12 Наличности на руках: 22.06
Сообщения: 38 Откуда: Netherlands
Good Evening
i have an acer E1-572,(V5WE2...LA-9532P) which starts with a blackscreen, i have tested all voltages 5volt, 3.3volt, 1.3 volt, 1.5volt, are present and laptop functions normal as it should, only black screen, also on external display via hdmi/vga no picture,.laptop can be switched on and off from power button, cpu is getting hot as normal, no water/liquid damage..
i have took a backup/dump of bios with ch341A, and then reflashed that dump, no change, downloaded .BIN bios from a site for the same board, flahed with programmer, NO change,
later saw on different forums that a bios.FD file must be extracted from bios then flashing with USB pen Drive, i dont know how to extract it,.
will someone spare a few minutes of their time and extract that file for me, i have attached original bios.DUMP and original from acer website,
Thanks alot
Uomo
Заголовок сообщения: Re: Acer E1-572 (LA-9532P) Black screen Добавлено: 26 дек 2020, 12:25 |
Зарегистрирован: 17 апр 2015, 13:31 Наличности на руках: 133.30
Сообщения: 3456 Откуда: Україна, Івано-Франківськ
frankmnldcheck this CLEAR ME! V5WE2 LA-9532p. do not forget, when flashing the BIOS, pull out the RTC batterycheck resistance USB lines D+/D- , and check resistance +RTCVCC ( D22 )
