Текущее время: 22 ноя 2024, 00:37
 Заголовок сообщения: Acer Aspire 5733Z (LA-6582P) Turns off after 5 minutes
СообщениеДобавлено: 09 дек 2013, 16:42
hello
i have an Acer Aspire 5733Z that turns off after exactly 5 minutes after pushing the power on button.
it dose not overheat, so please no posts regarding cleaning the cooling system.
what i have don until now:
Flashed 3 versions of different BIOS + EC
changed the BD82HM55 with new one
tried with different CPU
Changed osscilators Y1,Y2,Y6 and X1
Any other ideas?
thank you
 Заголовок сообщения: Re: Acer Aspire 5733Z (LA-6582P) Turns off after 5 minutes
СообщениеДобавлено: 09 дек 2013, 22:28
dump or clear ME?
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 09 дек 2013, 22:42
What do you mean? Do you want me to read the bios and ec and post here the dump?
I don't understand. Sorry. How to clear ME?
СообщениеДобавлено: 09 дек 2013, 23:14
ok. remove RTC battery and Flash bios from mail. After connect RTC battery.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 10 дек 2013, 00:38
thank you very much. i will try this first thing in the morning and post the result!
СообщениеДобавлено: 10 дек 2013, 13:51
thank you again. it worked like a charm.
just for me to understand...after first boot it writes some data on the EC rom?
is there any way to manually clear the ME, if i have a previously read EC rom?
СообщениеДобавлено: 10 дек 2013, 14:18
https://vlab.su/viewtopic.php?f=181&t=6897
https://vlab.su/viewtopic.php?f=181&t=7012
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 12 окт 2014, 10:29
Please could you send that bios file to me , and I have read topic at https://vlab.su/viewtopic.php?f=181&t=7012 using google translate but I could not understand , so could you make that steps More clearly and precisely , and thank so much........
СообщениеДобавлено: 05 янв 2015, 19:25
Hi guys, could someone send me files too, because I have same problem.
В этой теме нет новых непрочитанных сообщений. Acer 5741G (Compal LA-5891P) turns off after 4-5 minutes by itself
latitude
4900
23 апр 2015, 17:42
latitude Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. mb40ii5 (neo (clevo oem)) turns off about 5 minutes on battery
в форуме Clevo
adonis827
03 май 2016, 18:20
adonis827 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. T61 (lenovo) off after a few minutes
eletmoraes
02 дек 2014, 21:41
lionic Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. svf15 (GD6) turn off after 2 about minutes
в форуме Sony
R EZ A
23 окт 2023, 13:40
R EZ A Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. notebook dell vostro 3500 (Dell Vostro 3500 056tk2 10865) heats up and turns off after a few seconds
в форуме Dell
eletmoraes
28 апр 2018, 02:11
eletmoraes Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot], uran и гости: 78
