Текущее время: 19 ноя 2026, 09:15
 Заголовок сообщения: PlayStation 4 FAT SAA-001  [РЕШЕНО]
СообщениеДобавлено: 11 апр 2023, 16:57
Сонька в вечной синьке, инициализации соответственно нет, ранее делали реболл на ней, кто не знаю. Считал дамп, активировал UART и немного прифигел от лога.
msk0: PHY FIFO underrun/overflow.
secure loader build: Jun 8 2021 05:20:42 (r10426:release_branches/release_08.520) [711MHz]AGESA: ThebePBDK W5C21 963 msec[BOOT TIME] SAMU: 1378 msec: enter[BOOT TIME] SAMU: 2348 msec: leaveAGESA: ThebePBDK_3.1.0.70908 SAMU: W5C21
SIE CONFIDENTIAL
Copyright (C) 2021 Sony Interactive Entertainment Inc.
All Rights Reserved.
Copyright (c) 1992-2012 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
r174732/release_branches/release_08.520 Jun 8 2021 05:27:23 amd64
mDBG: Kernel Build ID = 8886cd5b8b34a937
CPU: DG1000FGF84HT (1594.00-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x710f13 Family = 16 Model = 11 Stepping = 3
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x36d8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,AVX,F16C>
AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
AMD Features2=0x154837fb<LAHF,CMP,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,NodeId,Topology,PerfCtrExtNB,<b26>,<b28>>
TSC: P-state invariant, performance statistics
Event timer "LAPIC" quality 400
ACPI APIC Table: <SIE ORBIS >
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 8 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
cpu2 (AP): APIC ID: 2
cpu3 (AP): APIC ID: 3
cpu4 (AP): APIC ID: 4
cpu5 (AP): APIC ID: 5
cpu6 (AP): APIC ID: 6
cpu7 (AP): APIC ID: 7
MADT: Could not find APIC for SCI IRQ 9
Memory mode: 4: BC8 release
BigApp memory : 0x0000000148000000 bytes (5248MiB)
FMEM (max) : 0x0000000020000000 bytes ( 512MiB)
MiniApp DMEM : 0x0000000030000000 bytes ( 768MiB)
VSH DMEM : 0x000000001a800000 bytes ( 424MiB)
Trace memory & Trace DMEM : 0x0000000000000000 bytes ( 0MiB)
Vision memory : 0x0000000001000000 bytes ( 16MiB)
Reserved memory : 0x0000000011a00000 bytes ( 282MiB)
Flexible memory(SYSTEM) : 0x000000004caac000 bytes (1227MiB)
BIOS memory size : 0x00000000011b8000 bytes ( 18MiB)
Kernel static size : 0x000000000d19c000 bytes ( 210MiB)
[REGMGR] 000001 ...
acpi0: <SIE ORBIS> on motherboard
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
cpu2: <ACPI CPU> on acpi0
cpu3: <ACPI CPU> on acpi0
cpu4: <ACPI CPU> on acpi0
cpu5: <ACPI CPU> on acpi0
cpu6: <ACPI CPU> on acpi0
cpu7: <ACPI CPU> on acpi0
pcib0: <ACPI Host-PCI bridge> on acpi0
pci0: <ACPI PCI bus> on pcib0
pci0: found pcie_glue
iommu0: <AMD IOMMU> on pci0
gc0: <Starsha> on pci0
LVP B2.1
# use 0x00000000 as mmGB_ADDR_CONFIG value
GC SE0 Redundant CU: 0x200
GC SE1 Redundant CU: 0x200
GC SE2 Redundant CU: 0x0
GC SE3 Redundant CU: 0x0
SClkVid:0x3c SClkDpmVid:3 Dpm:3 Vid:0x3c
hdac0: <GPU/DEHT Audio Controller> on pci0
apcie0: <Aeolia PCI Express glue> on pci0
apcie0: Chip revision: 00000300
apcie0: Chip ID0: 33c30130
apcie0: Chip ID1: 531310fe
icc0: <Aeolia ICC> on pci0
hpet_pci0: <Aeolia High Precision Event Timer> on pci0
Timecounter "HPET" frequency 10000000 Hz quality 950
Event timer "HPET" frequency 10000000 Hz quality 450
Event timer "HPET1" frequency 10000000 Hz quality 450
Event timer "HPET2" frequency 10000000 Hz quality 450
Event timer "HPET3" frequency 10000000 Hz quality 450
sflash0: <Aeolia Serial Flash I/F> on pci0
sflash0: Macronix(c2)
rtc0: <Aeolia RTC> on pci0
timer_mvl0: <Aeolia Timer/WDT> on pci0
uart0: <Non-standard ns8250 class UART with FIFOs> on pci0
uart0: uart_bus_attach
uart0: console (115200,n,8,1)
twsi0: <Aeolia TWSI> on pci0
ahci0: <Orbis Aeolia AHCI SATA controller> on pci0
ahci0: Aeolia SATA PHY init
[SATA] Apply ATE SRAM RTC Setting Version: 0x1
ahci0: Aeolia SATA PHY ID : 0x2100
ahci0: PHY calibration result[align90]: 0x5f
ahci0: AHCI v1.30 with 1 3Gbps ports, Port Multiplier supported with FBS
ahcich0: <AHCI channel> at channel 0 on ahci0
iommu_add_device_table_entry: device_id:00a2 dev:1 func:1 ahcich
xhci0: <Aeolia XHCI USB 3.0 controller> on pci0
xhci1: <Aeolia XHCI USB 3.0 controller> on pci0
iommu_add_device_table_entry: device_id:00a7 dev:20 func:7 xhci
Initial IO PTB alloc. device:0xa7 io:0xa000000
usbus1 on xhci1
xhci2: <Aeolia XHCI USB 3.0 controller> on pci0
acpi_ssb0: <Aeolia acpi> on pci0
mskc0: <Aeolia GBE controller> on pci0
iommu_add_device_table_entry: device_id:00a1 dev:20 func:1 mskc
msk0: <Aeolia GBE Id:0xbd Rev:0x01> on mskc0
eth0: Ethernet address: 70:9e:29:c3:5e:71
sdhci0: <Aeolia SDHCI> on pci0
iommu_add_device_table_entry: device_id:00a3 dev:20 func:3 sdhci
sdhci0: 1 slot(s) allocated
dmac0: <Aeolia DMA1 controller> on pci0
iommu_add_device_table_entry: device_id:00a5 dev:20 func:5 dmac
dmac1: <Aeolia DMA2 controller> on pci0
spm0: <Aeolia Scratch Pad Memory> on pci0
sbram0: <Aeolia DDR3 memory> on pci0
dct0: <SCE DCT driver> on hostb4
sbi0: <SCE SBI driver> on hostb5
gbase_register_interrupt_handler(52)
gbase_register_interrupt_handler(53)
dce: 23
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
_sdma_hw_init(0): microcode loaded
_sdma_hw_init(1): microcode loaded
acpDecFlac: <Codec DecFlac built on Jun 8 2021 05:26:35>
acpDecOpus: <Codec DecOpus built on Jun 8 2021 05:26:35>
ajm: <Audio CoProcessor Job Manager built on Jun 8 2021 05:26:33>
acpDecMp3: <Codec DecMp3 built on Jun 8 2021 05:26:31>
acpDecAt9: <Codec DecAt9 built on Jun 8 2021 05:26:35>
acpDecM4aac: <Codec DecM4aac built on Jun 8 2021 05:26:35>
acpEncM4Aac: <Codec EncM4Aac built on Jun 8 2021 05:26:35>
acpDecCelp8: <Codec DecCelp8 built on Jun 8 2021 05:26:35>
acpEncCelp8: <Codec EncCelp8 built on Jun 8 2021 05:26:35>
acpDecAc3: <Codec DecAc3 built on Jun 8 2021 05:26:35>
acpEncAc3: <Codec EncAc3 built on Jun 8 2021 05:26:35>
acpDecTrhd: <Codec DecTrhd built on Jun 8 2021 05:26:35>
acpDecM2bc: <Codec DecM2bc built on Jun 8 2021 05:26:35>
acpEncDts: <Codec EncDts built on Jun 8 2021 05:26:35>
acpDecM4aacfng: <Codec DecM4aacfng built on Jun 8 2021 05:26:35>
acpDecCelp: <Codec DecCelp built on Jun 8 2021 05:26:35>
acpEncCelp: <Codec EncCelp built on Jun 8 2021 05:26:31>
acpDecVorbis: <Codec DecVorbis built on Jun 8 2021 05:26:35>
acpEncOpusCelt: <Codec EncOpusCelt built on Jun 8 2021 05:26:35>
acpDecOpusCelt: <Codec DecOpusCelt built on Jun 8 2021 05:26:35>
acpEncOpusSilk: <Codec EncOpusSilk built on Jun 8 2021 05:26:35>
acpDecOpusSilk: <Codec DecOpusSilk built on Jun 8 2021 05:26:35>
acpUtlSrc: <Codec UtlSrc built on Jun 8 2021 05:26:35>
UVFAT_Initialize: exit
Timecounters tick every 1.000 msec
Session ID: ebe3a871634f3c303ba8942b7f649141
g_lvusbus1: 5.0Gbps Super Speed USB v3.0
Причем данная ошибка идет бесконечно msk0: PHY FIFO underrun/overflow.
очень похоже на неисправность процессора или ПО
Хотя по ПО чек лист
Final Count:
OK: 604
Warning: 0
Danger: 0
Unlisted: 0
Быстрое дополнение, PHY FIFO хз как это связано, упоминание данного значения есть протоколе LAN, снял Internet контроллер. Ситуация изменилась.
Теперь консоль переходит в белый
secure loader build: Jun 8 2021 05:20:42 БЕЛЫЙ ОГОНЬ
secure loader build: Jun 8 2021 05:20:42 (r10426:release_branches/release_08.520) [711MHz]AGESA: ThebePBDK W5C21 983 msec[BOOT TIME] SAMU: 1369 msec: enter[BOOT TIME] SAMU: 2360 msec: leaveAGESA: ThebePBDK_3.1.0.70908 SAMU: W5C21
SIE CONFIDENTIAL
FreeBSD is a registered trademark of The FreeBSD Foundatio800000 bytes ( 424MiB)
Flexible memory(SYSTEM) : 0x000000004cb84000 bytes (1228MiB)
Kernel static size : 0x000000000d0c4000 bytes ( 209MiB)
[REGMGR] 000001 ...
LVP B2.1
usbus1 on xhci1
dce: 23
Session ID: 4b7b9703dcd124e242a2f3b74702a67e
eth0: link state changed to UP
ahciugen1.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus1
uhub1: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus1
d_init 353 : Layered vnode device is initialized.
g_lvd_init 355 : lvd is built at 05:26:37 Jun 8 2021
GEOM_CRYPT: eap key setup
iommu_add_device_table_entry: device_id:00a4 dev:20 func:4 sflash
icc08-4001 0802
icc:failed to enabled reset button notification: 0005
icc:enabled thermal notification
[REGMGR] 000002 ...
[REGMGR] C00027 @8716294@@1@@30@@432@@0@@0@ ...
[REGMGR] 001001 $14684$@1@$13978948$# #$137771694779716$@387@############ ...
[REGMGR] C00004 @559@@1024@ ...
[REGMGR] C00005 @77@@1280@ ...
[REGMGR] C00006 @124078@@204800@ ...
[REGMGR] C00007 @1@ ...
[REGMGR] C00008 @198@ ...
[REGMGR] C00009 @458@@7280@ ...
[REGMGR] 000101 @8716294@@8716294@ ...
[REGMGR] ( 0.033325 sec) 010001 ...
[REGMGR] ( 0.357 sec) 010001 ...
uhub1: 2 ports with 2 removable, self powered
[HDMI] Set CEC FeatureTable [Normal]
mmc0: <MMC/SD bus> on sdhci0
[HDMI] HDMI kernel module has been available
trsw0 on sdio0
bt0 on sdio0
trs0 on sdio0
sdio0: <SDIO Device> at mmc0
SMP: AP CPU #7 Launched!
SMP: AP CPU #1 Launched!
SMP: AP CPU #5 Launched!
SMP: AP CPU #3 Launched!
SMP: AP CPU #4 Launched!
SMP: AP CPU #2 Launched!
SMP: AP CPU #6 Launched!
TSC clock: 1593818138 Hz
Timecounter "TSC-low" frequency 12451704 Hz quality 1000
trsw0: FW version : 14.130.16.p55
wlan0: Ethernet address: e8:61:7e:52:6d:0b
wlan1: Ethernet address: e8:61:7e:52:6d:0b
Trying to mount root from exfatfs:md0 []...
rtc0: WARNING: Battery failure indication
rtc0: Status:E9, Time:A8
RTC device error: Set Usertime 1970/01/01
usbus0 on xhci0
usbus0: 5.0Gbps Super Speed USB v3.0
ugen0.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus0
uhub0: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[SceSysCore mini] launched
*** start manu_cert ***
Special Wake is invalid
usbus2 on xhci2
usbus2: 5.0Gbps [SceSysAvControl] launched
[ [AvSetting shm:54] server stat.st_size = 4096
av Scontrolu pk] : f=setuer Speed USp_dispclk_k l=332 ucPpll=EXT_PLL1
B v3.0
ugen2.1[av control] : HdmiCheckAvailability HDMI-TxType[0x1] HDMI-DevOut[0x1]
[av control] : HdmiSetHdmiAvailability FLV1
: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0x0000 depth=0 port=1 speed=4) at usbus2
uhub2: <0x104d XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus2
set CEC ON
* [AvSetting core:1547] wait for hdmi event
* [AvSetting core:1552] hdmi not connected
** cpv:e1 **
** set_mode ** -1/-1
video: port:0 1080P_5994 RGB444 full CERGB 24bpp 1uhub0: 2 ports with 2 removable, self powered
6:9 nodata n-s
audio: port:HDMI src:I2S 48k 2.0 24bit fmt:LPCM LPCM null
[av control] : 1080P_5994 RGB444 CERGB 24bpp LT=Normal
[av control] : LinkRate(2.7Gbps), HDMI(FLV1)
[av control] : lt_req=1 hdmi_misc_up_req=1 vr_flg_up_req=0 vr_switch=0 csc_dir_req=0 hdr_dir_req=0
uhub2: 2 ports with 2 removable, self powered
*** Hdmi Init(kern) : 0 ***
ERROR: _secure_read_raw(339) !CMDRSP_HDR_OSC_STOP
ERROR: _rtc_read_pre(461) _secure_read_raw ret=0x800f0531
ERROR: _rtc_read(486) rtc_read_pre ret=0x800f0531
[av control] : f=HdmiSetup videoConfigType(NORMAL)
*** Hdmi Setup(kern) : 0 ***
** set_mode done (9550883404:466) **
[avs] update -1:27
[avs] lock -1:0
trsw0 on sdio0
bt0 on sdio0
trs0 on sdio0
usbus0 on xhci0
usbus2 on xhci2
B v3.0
uhub2: <0x104d XHCI root HUB, class 9/0, rev 3filecheck: /dev/da0x8 FAILED 2
[ERR] mount hdd [failed
REGMGR] (2549/6016072469926338939): E00042 @0@ ...
[REGMGR] 000401 ...
[REGMGR] ( 0.000439 sec) 010301 @0@ ...
[REGMGR] ( 0.000003 sec) 010302 @0@ ...
[REGMGR] 000103 @0@@8716294@ ...
[REGMGR] C00016 @0@@1@#OFF##OFF#@0@@0@ ...
[REGMGR] 000104 ...
[REGMGR] C00018 @1@ ...
[REGMGR] C00023 @8716294@@1@@4359@@63@@100912@@47604@ ...
[REGMGR] ( 0.168660 sec) 010003 ...
[REGMGR] ( 12.987 sec) 010003 ...
[SceSysCore mini] sceRegMgrCntlStart failed 800d0403
[SceSysCore mini] failed to mount system partitions
[SceSysCore mini] Reboot and boot with rescue mode...
[HDMI] Sink supports HDCP1.4 only
[HDMI] Monitor Type [HDMI]
[avs] hdmi event: connected(1), 0x9000000000100, 27995760000
[av control] : hdmi event connected(1)
* [AvSetting registry:966] not found
* [AvSetting registry:365] non-HDR TV: VIDEOOUT_hdr_off
[avs] update 27:30
[avs] lock 0:45
set CEC ON
** cpv:e1 **
video: port:0 1080P_5994 RGB444 limited CERGB 24bpp 16:9 nodata n-s
audio: port:HDMI src:I2S 48k 2.0 24bit fmt:LPCM LPCM once
[avs] update 30:15
[avs] lock 45:0
[avs] hdmi event: disconnected(0), 0x9000000000100, 28441988146
** set_mode done (28724502368:447) **
[av control] : hdmi event disconnected(0)
[avs] update 15:32
[avs] hdmi event: connected(1), 0x9000000000200, 28946379960
** cpv:e1 **
[av control] : lt_req=1 hdmi_misc_up_req=0 vr_flg_up_req=0 vr_switch=0 csc_dir_req=0 hdr_dir_req=0
[avs] update 32:15
** set_mode done (30906444220:1229) **
[avs] update 15:32
filecheck: /dev/da0x6x2.crypt FAILED 2
[ERR] mount hdd failed
[SceSysCore mini] find_hdd /dev/da0x6x2.crypt failed -1
[REGMGR] 000006 ...
[REGMGR] ( 0.000000 sec) 010007 ...
[REGMGR] 000107 ...
Waiting (max 60 seconds) for system process `SceVnlru' to stop...done
WHaIDit i:n Cgon t(romlalx e6r 0U SsB Coennceocntidosn )0
foHrI Ds y: sotpe:0m0 0pr0o0c0es0s0 `bSt:c1e uBsubf:0d arege:m1
on1' to stop...done
Waiting (max 60 seconds) for system process `SceBufdaemon0' to stop...done
Waiting (max 60 seconds) for system process `SceSyncer' to stop...
Syncing disks, vnodes remaining...0 sched_sync: flush softdep (iter=2)
sched_sync: flush softdep (iter=1)
done
Waiting (max 60 seconds) for system process `SceBufdaemon2' to stop...done
All buffers synced.
[REGMGR] (8719/137720138263933): E00604 @35@ ...
Uptime: 29s
icc post sync:Thermal alert LED off
[REGMGR] 000007 @2@ ...
icc08-4001 0802
icc:failed to disabled reset button notification: 0005
icc:disabled thermal notification
icc02-4010 0203
ICC: howto:00000000 depth:2 cause:00 hand:01
ICC: Reboot.
ICC 04-01 nowait
secure loader build: Jun 8 2021 05:20:42 (r10426:release_branches/release_08.520) [711MHz]AGESA: ThebePBDK W5C21 973 msec[BOOT TIME] SAMU: 1261 msec: enter[BOOT TIME] SAMU: 2242 msec: leaveAGESA: ThebePBDK_3.1.0.70908 SAMU: W5C21
SIE CONFIDENTIAL
Flexible memory(SYSTEM) : 0x000000004ca74000 bytes (1227MiB)
Kernel static size : 0x000000000d1d4000 bytes ( 210MiB)
[REGMGR] 000001 ...
LVP B2.1
usbus1 on xhci1
dce: 23
Session ID: c9fedb67870aa0d0895a626651921d37
icc08-4001 0802
[REGMGR] 000002 ...
[REGMGR] C00008 @199@ ...
[REGMGR] ( 0.033332 sec) 010001 ...
[REGMGR] ( 0.337 sec) 010001 ...
trsw0 on sdio0
bt0 on sdio0
trs0 on sdio0
TSC clock: 1593777612 Hz
Timecounter "TSC-low" frequency 12451387 Hz quality 1000
usbus0 on xhci0
H[SceSysCore mini] Entering rescue mode(0xf0)...
usbusID 2: oopn xhci2
:0u00sb0u0s0032 b:t[SceSysAvControl] launched
[:a [AvSetting shm:54] server stat.st_size = 4096
05v. u0 Gcsonbbt:ps1 r roSegl:u p0
ekr] Sp:e fed =sUSeB tvu3.p0
ugen2.1: <0x104d, XHCI root HUB, >(VID=0x0000 PID=0[av control] : HdmiCheckAvailability HDMI-TxType[0x1] HDMI-DevOut[0x1]
[REGMGR] (2549/4999134440476076389): E00042 @0@ ...
[REGMGR] 000401 ...
[REGMGR] ( 0.000442 sec) 010301 @0@ ...
[REGMGR]** cpv:e1 **
video: port:0 480P_5994 RGB444 limited CERGB 24bpp 16:9 nodata n-s
[av control] : 480P_5994 RGB444 CERGB 24bpp LT=Normal
[REGMGR] 000104 ...
[REGMGR] ( 0.200710 sec) 010003 ...
[REGMGR] ( 10.435 sec) 010003 ...
* [mbus:929] [MBUS WARN] DISCONNECTED event from HDMI in DISCONNECTED state
* [mbus:350] disconnected(0) from unknown device
[ERROR]sceKernelWaitEventFlag(SCE_BOOT_STAT_DISPLAY, SCE_KERNEL_EVF_WAITMODE_AND) result 2000 : 8002003c
[AppFramework2][ERROR Initialize:67]cam_open_device(/dev/cd0) failed! (errno:0x2)
** set_mode done (37654123364:9915) **
try GET_HDMI_STATE (0)
try GET_HDMI_STATE (16)
try GET_HDMI_STATE (32)
[AppFramework2][ERROR init:488]EjectButtonListener::Initialize error (result:0x80182b19)
try GET_HDMI_STATE (48)
GET_HDMI_STATE failed
** cpv:e1 **
** set_mode done (47680555266:1243) **
GET_HDMI_STATE failed видим что не определяет подключенный HDMI, бедем копать обвязку или сам контроллер.
И еще дополнение: Мертвый контроллер оказался, зашибло его. Заменил, картинка появилась.
Всем спасибо за помощь, расходимся :))))) ::yaz-yk:
В этой теме нет новых непрочитанных сообщений. Playstation 4 рабочая плата SAA-001
Apexwin
10 фев 2017, 12:02
Apexwin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. PS4 FAT SAA-001 не загружается ПО (логотип PS и синий огонь)
Hypnochel
4141
15 июн 2022, 13:36
Delfin- Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Нумерация банок памяти на PS4 FAT (SAA-001)
damned2000
07 ноя 2021, 02:06
damned2000 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. PS4 FAT (SAA-001) Ищу дамп с прошивкой 1.62
damned2000
19 мар 2022, 20:43
В этой теме нет новых непрочитанных сообщений. Sony PS4 Fat SAA-001 банки памяти.
tuatara
3915
05 апр 2026, 20:30
oleggamer Перейти к последнему сообщению
Сейчас этот форум просматривают: Bormaxxx, voin22 и гости: 9
