Текущее время: 21 ноя 2026, 04:15
 Заголовок сообщения: Lenovo Legion 5-15ACH6H (NM-D562 rev:2.0) no pictures after flash bios
СообщениеДобавлено: 11 апр 2023, 17:55
Fans stop spin and i flash bios ,but after no picture any more all power voltage are present..Please help
 Заголовок сообщения: Re: Lenovo Legion 5-15ACH6H (NM-D562 rev:2.0) no pictures after flash bios
СообщениеДобавлено: 11 апр 2023, 18:37
How can I help you ?
СообщениеДобавлено: 11 апр 2023, 20:27
After flash bios from this site ,doesn't turn picture on screen I save old one, again I flash bios but same result ,I don't understand why this happen ..I measure by oscilloscope on 2 leg of bios no signal :(
СообщениеДобавлено: 11 апр 2023, 20:43
and before that it was ?
СообщениеДобавлено: 11 апр 2023, 20:58
Before was ok,only fan didn't spin ,I decide flash bios after black screen ..On fan red voltage only 0.200 v..
СообщениеДобавлено: 11 апр 2023, 21:11
pcexpert8 писал(а):
Before was ok
why flash it then?
put another fan in first to check
p.s. fan controlled by multicontroller
perhaps something has been taken down. maybe you need to flash the multicontroller
and what to say without measurements. there processor ryzen ?
СообщениеДобавлено: 11 апр 2023, 21:57
It Ryzen CPU..I did by vertyanov flash EC .. Before I change fans ,I test fans by power supply spin norma(fans are ok)..Before flash bios laptop was working ,only fans did not spin ,that is reason why idecide flash bios..Better If I was not flash,but now is late:(
 Заголовок сообщения: Re: Lenovo Legion 5-15ACH6H (NM-D562 rev:2.0) no pictures after flash bios  [РЕШЕНО]
СообщениеДобавлено: 12 апр 2023, 14:13
this is my old bios and EC..Wow i flash bios with programmer 1.8v and laptop turn on..But fans not spin:(this bios are working )
I found issue for fans this was damage (AOZ2151EQ)PU7901 i chnage it now fans working Thank you
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Legion 5-15ACH6H (nm-d562 rev:3) нет изображения на экране
pcexpert8
3964
14 июл 2024, 09:01
pcexpert8 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo Legion 5 15ACH6H ((Compal NM-D562 Rev 2.0))) Опознать микросхему
fetefix021
04 ноя 2023, 15:09
ZZZ7ZZZ Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Legion 5 15ACH6H 82JU (NM-D562 Rev:2.0) Стартует, звук приветствия, изо нигде нет
dhs6512
12
3491
16 окт 2024, 23:29
dhs6512 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Legion 5-15ACH6H (NM-D562 REV 3.0) Не всегда запускается
Андрей_74
12 дек 2024, 17:13
Андрей_74 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo Legion 5 15ACH6H (NM-D562 rev 2.0) не включается, не заряжается
ra6yee
20
2845
09 ноя 2025, 20:54
ra6yee Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 74
