trollfaceololo писал(а):
To disable the built-in RAM, try setting PCBID 0-1-2 to 111. Find the board and check 3 resistors (2 near the CPU and one on the other side of the board).
From what I saw on the schematics, PCBID2 and PCBID1 are pulled down by a 2.2K resistor (r0918 and r0917) ..... r0914 and r0915 are missing ...
PCBID0 voltage is determined by a resistor divider 2.2k / 10k .... so it's about 0.54v ..... this is enough to have a 1??
If so, to get 1 1 1 you have to add 2 10k (r0914 and r0915) .... am I right?
TIA
