my friend asus x542uq charging problem turns off when the charger is unplugged, it turns on when you plug in the charger, the battery charge rate seems 100% full thanks
_________________ asliyucegsm car and laptop chipset repair asliyuce_elektronic Electronic circuit boards and motherboard repair
MoneyBot
Заголовок сообщения: asus x542uq (rev.2.0) charge problem battery
Mardekai
Заголовок сообщения: Re: asus x542uq (rev.2.0) charge problem battery
Добавлено: 23 июн 2023, 22:59
Зарегистрирован: 28 июл 2016, 22:01 Наличности на руках: 893.89 Сообщения: 1484 Откуда: Москва
try tightening that screw
harun
