Текущее время: 15 июн 2024, 23:32
 Страница 1 из 1 [ Сообщений: 19 ]
 Заголовок сообщения: Вопрос о прошивке Kingston SA40037/120
СообщениеДобавлено: 09 авг 2023, 12:48
Здравствуйте. Попал в руки SSD Kingston SA40037/120. На плате SM2259XT
Flash ID
v0.565a
Drive: 0(ATA)
OS: 6.2 build 9200
Model: SM2259AB-80-10000000
Fw : 20141211
Size : 0 MB [0.0 GB]
Controller : SM2258AA in ROM Mode
Bank00: 0x89,0xa4,0x8,0x32,0xa1,0x0,0x0,0x0 - Intel 64L(B16A) TLC 256Gb/CE 256Gb/die
Bank01: 0x89,0xa4,0x8,0x32,0xa1,0x0,0x0,0x0 - Intel 64L(B16A) TLC 256Gb/CE 256Gb/die
Bank02: 0x89,0xa4,0x8,0x32,0xa1,0x0,0x0,0x0 - Intel 64L(B16A) TLC 256Gb/CE 256Gb/die
Bank03: 0x89,0xa4,0x8,0x32,0xa1,0x0,0x0,0x0 - Intel 64L(B16A) TLC 256Gb/CE 256Gb/die
Bank04: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank05: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank06: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank07: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank08: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank09: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank10: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank11: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank12: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank13: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank14: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank15: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank16: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank17: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank18: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank19: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank20: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank21: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank22: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank23: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank24: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank25: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank26: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank27: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank28: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank29: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank30: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Bank31: 0xff,0xff,0xff,0xff,0xff,0xff,0x0,0x0 -
Какая прошивка будет работать для Intel 64L(B16A) TLC 256Gb/CE 256Gb/die ?
 Заголовок сообщения: Re: Вопрос о прошивке Kingston SA40037/120
СообщениеДобавлено: 09 авг 2023, 13:07
не шьется ?
https://www.usbdev.ru/files/smi/sm2259mptool/
или SM2258_B16A_FWQ0824C_MPQ1016A
СообщениеДобавлено: 09 авг 2023, 14:46
jonpim писал(а):
не шьется ?
нет, Download MP Package FW. Нужно для 2259XT. Может есть инструкция как редактировать Flash.SET файл, что бы в списке флеш памяти отабражалась моя флешка?
СообщениеДобавлено: 09 авг 2023, 15:36
бери файл Flash.SET из этого тула - https://www.usbdev.ru/files/smi/sm2259mptool/
gevorg-x писал(а):
Нужно для 2259XT
Нанды b16a для контроллера SM2258XT
СообщениеДобавлено: 09 авг 2023, 16:06
Пробовал, Перекинул в 2259XT, ругается на data base
СообщениеДобавлено: 09 авг 2023, 16:57
gevorg-x писал(а):
нет
Так какой процессор на плате ?
Фото бы платы для ясности , чтобы 10 раз не переспрашивать .
И мастерам в копилку )
СообщениеДобавлено: 09 авг 2023, 18:32
Может 2259XT2G ? Для них B16A были .
"Анархия -мать порядка " - вольная трактовка "Теории хаоса "
В сети
СообщениеДобавлено: 10 авг 2023, 08:43
---------- Добавлено спустя 24 минуты 50 секунд: ----------
Да, знаю, но тоже не идет прошивка
СообщениеДобавлено: 10 авг 2023, 11:38
А этим не пробовали ?
В сети
СообщениеДобавлено: 10 авг 2023, 12:13
Да, остается в режиме Download MP Package FW до бесконечности
СообщениеДобавлено: 10 авг 2023, 12:22
А USB-SATA переходник сменить ?
В сети
СообщениеДобавлено: 10 авг 2023, 12:23
пробовал и напрямую через Sata кабель. Результат тот же.
СообщениеДобавлено: 10 авг 2023, 12:28
По SATA я не смог прошить ни один диск с контроллером SMxxxx .
В сети
СообщениеДобавлено: 10 авг 2023, 12:29
SM2259XT не поддерживает dram
SM2259 используют с буфером dram .
Нужно пробовать срастить с тулом для SM2258XT , b16a старая память .
Последний раз редактировалось jonpim 10 авг 2023, 12:34, всего редактировалось 1 раз.
СообщениеДобавлено: 10 авг 2023, 12:30
у меня проблем не было с этим
---------- Добавлено спустя 24 секунды: ----------
можно подробнее?
СообщениеДобавлено: 10 авг 2023, 12:35
gevorg-x писал(а):
можно подробнее?
Так видно по настройкам этих тулов .
СообщениеДобавлено: 10 авг 2023, 12:42
С SM2258XT такая беда, пробовал несколько штук, на всех такая ошибка
СообщениеДобавлено: 10 авг 2023, 12:58
gevorg-x писал(а):
для Intel 64L(B16A)
по поиску в гугл fh64b08ucn1 это ребрэндинг тошибы - https://www.techpowerup.com/ssd-specs/k ... 40-gb.d287
 Заголовок сообщения: Re: Вопрос о прошивке Kingston SA40037/120  [РЕШЕНО]
СообщениеДобавлено: 10 авг 2023, 14:04
да... и тут сказанно, что поставили 2258x и даже 2259xt как в моем случае.
---------- Добавлено спустя 2 часа 5 минут 50 секунд: ----------
УРААА!!!! получилось!!!! Без редактирования не обошлось. Значит что я сделал:
Из SM2259_B16_MPT0506A_FWT0116C_RDTFIX взял параметры флешки из файла Flash.SET и скопировал в аналогичный файл но в SM2259XT B27A S0219A FWS0111A0 ; SM2259XT_B27A_PKGS0219A. На других верисях тоже получилось, но прошивка длилась больше 5 минут. А в SM2259XT B27A S0219A FWS0111A0 прошивка длится 35 секунд. Прилагаю готовый SM Tools. Не важно какой память из списка выбрать, будет работать для Intel 64L(B16A) TLC.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Omni 120 AiO PC ( 120-1202er ) (DA0WJ5MB6F0 REV: F) Нужен дамп BIOS+EC
fulgen
23 апр 2015, 17:02
Дмитрий Никулин Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Omni 120 AiO PC (120-1200en) (Quanta WJ5 (DA0WJ5MB6F0 REV: F )) проблема с драйвером видео от intel
DmitryKZ
25 янв 2016, 10:36
DmitryKZ Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP Omni 120 AiO PC (120-1204er) Полосы артефакты до загрузки ОС
vlsotov
03 апр 2023, 17:12
vlsotov Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. omni 120 aio pc 120-1106er (quanta wj5 rev f) Изредка загружается
в форуме HP
bvd
18 апр 2024, 18:47
DmitriyDDD Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GA-H61M-S2PV Не включается, вопрос по прошивке биос
в форуме Gigabyte
Akir1
12
8639
21 июл 2016, 15:47
makarog Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 0
