Текущее время: 26 июн 2024, 17:27
adeq4
Заголовок сообщения: Lenovo Legion Y740 ( LA-G132P) no sound from speaker ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 29 авг 2023, 01:04 |
Зарегистрирован: 14 май 2013, 11:43 Наличности на руках: 6.02 ![](./styles/AeroBlack/theme/images/money.png)
Hi, this thread concern laptop:
Lenovo Legion Y740-15IRHg Motherboard: LA-G132P
Problem: - no sound from speakers, headphones port working properly
What I did: - replacement audio codec ALC3268, - replacement audio amplifier TAS5766, - testing a lot of audio drivers, - speakers replacement, - testing on WIN10, WIN11 and Ubuntu, - bios programming, 3 different dumps, - replacement capacitors on amplifier out line.
None of the above steps resolve the problem. The system recognizes plugging the headphones - the volume of the audio output is automatically reduced. I checked different drivers under WIN11 and WIN10 - no improvement.
The 17" version doesn't have an amplifier, the audio is directed to the speakers directly from codec. I tried to desolder the amplifier and solder RA60 and RA61 resistors, hoping to test one channel. No success.
Measurements:
UA1 ALC3268 7. 3.36V 9. 3.33V without headphone, 2.25V with headphone 10. 3.36V 19. 3.36V 22. 1.44V 24. 1.84V 44. 4.34V 45. 5.08V 46. 5.08V 51. 5.08V 52. 3.28V
USA1 TAS5766 1. 3.36V 11. 3.36V 12. 20.2V 33. 3.36V 47. 1.82V
What else can I check? I suspect that it is software issue, I haven't idea how to repair it.
![](images/spacer.gif) |
eabor
Заголовок сообщения: Re: Lenovo Legion Y740 ( LA-G132P) no sound from speaker ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 14 окт 2023, 15:11 |
Зарегистрирован: 14 окт 2023, 15:00 Наличности на руках: 2.00 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 1 Откуда: Earth
Привет! Абсолютно похожая ситуация, но с Legion 5 pro 16ITH6. Есть дополнительные вводные, может быть поможет в поиске неисправности. На ноутбуке используется Ubuntu, звук из динамиков работал корректно до момента, когда было недостаточно громко, и я воспользовался функцией Over-amplification, которая позволяет увеличить громкость более 100%. При таком использовании перестал звучать правый динамик, левый работал, позже я снова попробовал увеличить громкость аналогичным способом, из-за чего перестал работать левый динамик, но правый заработал. Но через некоторое время такого использования перестали работать оба встроенных динамика, при этом вывод звука через наушники продолжает работать до сих пор. Проверил Динамики, они не сгорели, работают. Значит что-то выше по схеме вышло из строя. К слову, на старом ноутбуке такой способ увеличения громкости встроенных динамиков работал без проблем, потому пытался провернуть аналогичный трюк. Подскажите в какую сторону копать с учётом описанной ситуации?
hachikkz
Заголовок сообщения: Re: Lenovo Legion Y740 ( LA-G132P) no sound from speaker ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 31 май 2024, 17:21 |
![Аватара пользователя](./download/file.php?avatar=28726_1570983789.gif) |
Зарегистрирован: 03 апр 2014, 17:52 Наличности на руках: 370.14 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 138 Откуда: asd
adeq4 писал(а): USA1 TAS5766 1. 3.36V 11. 3.36V 12. 20.2V 33. 3.36V 47. 1.82V
What else can I check? I suspect that it is software issue, I haven't idea how to repair it. Для тех кто ещё столкнется с этой проблемой, не забудьте проверить напряжение GVDD на затворы внутренних транзисторов на 27 ноге усилителя tas5766m, должно быть около 7 вольт. У меня из-за пробитого конденсатора на этой линии не было звука.
Кто сейчас на конференции |
Сейчас этот форум просматривают: alexchech88, Brtth, evgenyjp, ivan111, maratcompas, mastermakc, sabitvrustam, Techniks, Vadim67, valera_sh, Yandex [BOT] и гости: 51 |
