Текущее время: 21 ноя 2026, 05:03
 Заголовок сообщения: a400 на 480гб надо прошить Intel? (глючит)
СообщениеДобавлено: 22 ноя 2023, 19:17
Приветствую.
Хочу его прошить. Прошивку к нему нашел (SBFKB1H5)
Но банки памяти в ssd Intel, в s11-flasher2 есть ток Micron и Toshiba, как быть?
Model: KINGSTON SA400S37480G
Fw : SBFKB1C2
P/N : 8199948
S11fw: SBFKB1C2, 2018May18
S11rv: KB1C2-17
Bank00: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank01: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank02: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank03: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank08: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank09: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank10: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Bank11: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die
Controller : PS3111
Flash CE : 8
Flash Channel : 2
Dram Size,MB : 32
Flash CE Mask : [++++---- ++++----]
Flash Mode/Clk: 5/7 (Set 5/7)
Block per Die : 2016
Block per CE : 2016
Page per Block: 2304
SLC Cache : Default
PE Cycle Limit: 1000
ParPage : 00
MaxBBPerPlane : 56
Plane : 4
Defects All(per plane) Early Later
Bank00: 11(4,4,2,1) 11(4,4,2,1) 0(0,0,0,0)
Bank01: 13(6,3,2,2) 13(6,3,2,2) 0(0,0,0,0)
Bank02: 13(5,4,1,3) 12(5,4,1,2) 1(0,0,0,1)
Bank03: 13(5,4,2,2) 13(5,4,2,2) 0(0,0,0,0)
Bank08: 14(6,4,2,2) 14(6,4,2,2) 0(0,0,0,0)
Bank09: 16(5,4,2,5) 16(5,4,2,5) 0(0,0,0,0)
Bank10: 13(5,4,2,2) 13(5,4,2,2) 0(0,0,0,0)
Bank11: 16(8,3,2,3) 16(8,3,2,3) 0(0,0,0,0)
Total : 109 108 1
Early defect list
Bank00: 16 765 1912 1913 1914 1915 2000 2001 2012 2013 2014
Bank01: 16 765 1912 1913 1914 1915 1972 2000 2001 2008 2012 2014 2015
Bank02: 16 765 1912 1913 1914 1915 2000 2001 2008 2012 2013 2015
Bank03: 16 765 1912 1913 1914 1915 1937 2000 2001 2008 2012 2014 2015
Bank08: 16 765 1912 1913 1914 1915 1954 2000 2001 2004 2008 2012 2013 2015
Bank09: 16 765 1912 1913 1914 1915 1929 2000 2001 2003 2007 2008 2011 2012 2014 2015
Bank10: 16 765 1912 1913 1914 1915 2000 2001 2008 2012 2013 2014 2015
Bank11: 16 765 1912 1913 1914 1915 1963 1992 1996 2000 2001 2004 2008 2012 2014 2015
Later defect list
Bank02: 1207
 Заголовок сообщения: Re: a400 на 480гб надо прошить Intel? (глючит)
СообщениеДобавлено: 24 ноя 2023, 15:55
Нажимай на кнопку микрон . Важнее выбор самой прошивки .
В флешере написано что она для qlc intel 96L (N28A)
Для вашей нанд - SBFMBB.3_16122020.BIN
СообщениеДобавлено: 25 ноя 2023, 13:05
jonpim
У меня такой же A400, только 120 , 2020 года, тоже SBFKB1H5, и отчет тоже Intel B17A показывает. Шиться увы не хочет, как и лечиться S11 repair.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 25 ноя 2023, 14:49
Светлая память
Светлая память
Есть у меня похожий, "волшебный" ssd goodram cx400 на контроллере Phison. У него раз в пол года, как по часам, прошивка слетает. Какого хрена так происходит я не знаю. Прошивается только из под WinPE Стрельца. s11-flasher2.15 с готовым бинарником всегда под рукой.
---------- Добавлено спустя 3 минуты 34 секунды: ----------
jhmax666 писал(а):
SBFKB1C2
В Firmware PS3111 есть SBFKB1C3 может эту прошивку стоит попробовать.
СообщениеДобавлено: 26 ноя 2023, 09:11
SSD MP Tool v2.2.85 показывает для B17A прошивку sbfqbb.3
Интересно в чем разница между прошивкой sbfmbb.3 ?
СообщениеДобавлено: 27 ноя 2023, 01:32
чем ифу по ссд вытягиваете?
СообщениеДобавлено: 27 ноя 2023, 19:34
http://vlo.name:3000/ssdtool/
-приворот winDOвSa
-розыгрыш автоБАНа
 Заголовок сообщения: Re: a400 на 480гб надо прошить Intel? (глючит)  [РЕШЕНО]
СообщениеДобавлено: 29 ноя 2023, 13:54
Спасибо !
Имеется 5 ссд разных фирм и моделей как узнать какой контроллер установлен? ssd-z не показывает. aida64 брешет. CrystalDiskInfo не показывает. Остаётся тыкать каждый диск из этого списка утелит http://vlo.name:3000/ssdtool/ !?
В этой теме нет новых непрочитанных сообщений. Восстановление данных Kingston A400
altavista_live
5531
17 ноя 2018, 19:47
Sergej Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Kingston A400 расшифровка маркировки
Mordoc
2379
18 май 2021, 11:45
Mordoc Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Надо прошить мульт IT8586E Lenovo в Харькове
в форуме Куплю | Buy
maks740
10 ноя 2020, 13:33
fixit Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. intel nuc nuc6i7kyk прошить bios
в форуме Intel
stud
6913
19 авг 2020, 20:28
stud Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Народ очухался "буки надо чинить!"
TSARIVAN
3084
23 дек 2016, 14:15
cron
