| Автор |
Valery_
Заголовок сообщения: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 06 янв 2024, 15:24 |
| Я тут случайно |
Сообщения: 18 Откуда: Minsk
2 одинаковых по составу микросхем SSD. Но в одном данные rtl_flash_id:
v0.15a Drive: 0(ATA) OS: 6.1 build 7601 Service Pack 1 ATA: SmartEnable failed! Error: 0x51 ATA: Identify failed! Error: 0x51 Model: REALTEK_RL6531 Fw : 3.AAE Size : 1 MB [0.0 GB] FwStr: [REALTEK_RL6531] ATA: Get FWI failed! Error: 0x51 Bank00: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank01: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank02: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank03: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank04: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die Bank05: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank06: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank07: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank08: 0x89,0xc4,0x8,0x32,0xa6,0x0,0x0,0x0 - Intel 64L(B17A) TLC 512Gb/CE 512Gb/die Bank09: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank10: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank11: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank12: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank13: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank14: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank15: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Flash CE Mask : [++++-+++ -+++++++]
а в другом данные rtl_flash_id:
v0.15a Drive: 0(ATA) OS: 6.1 build 7601 Service Pack 1 ATA: SmartEnable failed! Error: 0x51 ATA: Identify failed! Error: 0x51 Model: REALTEK_RL6531 Fw : 3.AAE Size : 1 MB [0.0 GB] FwStr: [REALTEK_RL6531] ATA: Get FWI failed! Error: 0x51 Bank00: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die Bank01: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die Bank02: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank03: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank04: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die Bank05: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die Bank06: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank07: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank08: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die Bank09: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die Bank10: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank11: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank12: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die Bank13: 0x2c,0xc4,0x18,0x32,0xa2,0x1,0x0,0x0 - Micron 96L(B27A) TLC 512Gb/CE 512Gb/die Bank14: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Bank15: 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff - Flash CE Mask : [++--++-- ++--++--]
вопрос: как определить где правильная информация и как восстановить (привести до правильной) неверный SSD. или возможен вариант что под одинаковым названием китайцы спрятали разные микросхемы? ---------- Добавлено спустя 1 час 3 минуты 7 секунд: ---------- на всякий случай добавлю фото.
MoneyBot
Заголовок сообщения: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7 |
jonpim
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 06 янв 2024, 17:00 |
| Продвинутый форумчанин |
Зарегистрирован: 26 дек 2010, 14:42 Наличности на руках: 767.93
Сообщения: 2033 Откуда: Vladivostok
Valery_ писал(а): как определить где правильная информация Сам мптул выдаст фид при включении диска в ром мод . Подобрать прошивку и главное это посмотреть количество бэдов каждом чипе . Иначе это мусор .
Valery_
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 07 янв 2024, 10:34 |
| Я тут случайно |
jonpim писал(а): Сам мптул выдаст фид при включении диска в ром мод . мптул при автодетекте выдает такую же информацию (В17А и В27А). но форматирование памяти не проводит - доходит только до Do LLF - и через некоторое время выскакивает ошибка - время закончилось. вот и возник вопрос о различии и достоверности информации о микросхемах
jonpim
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 07 янв 2024, 16:05 |
Valery_ писал(а): такую же информацию (В17А и В27А) Покажи скрин мптула . нанды одинаковые на фото , если оно родное .
Valery_
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 18 янв 2024, 14:37 |
| Я тут случайно |
jonpim писал(а): Покажи скрин мптула . может есть какой совет? в каком направлении двигаться?
jonpim
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 18 янв 2024, 15:37 |
Valery_ писал(а): фото оригинальное. Диски в ром переведены ?
Valery_
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 18 янв 2024, 20:07 |
| Я тут случайно |
jonpim писал(а): Диски в ром переведены ? извиняюсь за дилетантский вопрос: а как узнать что устройство перешло в режим Rom Mode? что с перемычкой,что без- комп определяет устройство как Realtek RL6531 ATA Device. подключаю через e-SATA.
jonpim
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 19 янв 2024, 09:34 |
Valery_ писал(а): что с перемычкой,что без- комп определяет устройство как Realtek RL6531 ATA Device. подключаю через e-SATA. Подключи через sata-usb мост . В мптуле сделай стирание с галками clear mode и dl mode . Это удалит старую инфу . Переподключить диск и далее автодетект определит нанды .
Valery_
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 27 янв 2024, 15:50 |
| Я тут случайно |
jonpim писал(а): https://aliexpress.ru/item/100500440356 ... 3280hosDwT в этом адаптере какой-то специфический контроллер? нашел адаптер в котором компьютер увидел SSD, но мптул устройство не нашел и flash_id микросхемы не увидел.
v0.15a Drive: 1(USB) OS: 6.1 build 7601 Service Pack 1 Model: REALTEK_RL6531 Fw : 3.AAE Size : 1 MB [0.0 GB] FwStr: [REALTEK_RL6531] Flash CE Mask : [-------- --------] Banks : 0 Channel : 0 CE : 0 Die/CE : 0 Plane : 0 Block/Die : 0 Page/Block : 0 Sect/Page : 0 FullPageSize: 0 MaxCapacity : 0 MaxPECycle : 0 SharedPages : 0 GCFreeLimit : 0
Fabric Bad block list (bank0 only):
Later Bad block list (bank0 only): Bank0 BB (Fabric+Later): 0 (0+0)
sergey.kochetkoff
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 02 дек 2024, 05:23 |
| Я тут случайно |
Сообщения: 4 Откуда: Алтай
Valery_ писал(а): возможно какой-то специфический адаптер(например на jm20329) У меня определился и работает с адаптер SATA->USB USB 3.0 (USB 3.1 gen1) type-a на контроллере JMS578
MoneyBot
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7 |
Valery_
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 03 дек 2024, 19:48 |
| Я тут случайно |
sergey.kochetkoff писал(а): У меня определился и работает с адаптер SATA->USB USB 3.0 (USB 3.1 gen1) type-a на контроллере JMS578 sergey.kochetkoff писал(а): Вы смогли найти прошивку под своё устройство?
не понятен вопрос если у Вас работает.Хотите помочь? )
sergey.kochetkoff
Заголовок сообщения: Re: Fake SSD на RL6531 (RTS5733DL) и памяти 29FSRHB3BJATH7  Добавлено: 04 дек 2024, 02:46 |
| Я тут случайно |
sergey.kochetkoff писал(а): возможно какой-то специфический адаптер(например на jm20329) надо.не проходит LLF Valery_ писал(а): У меня определился и работает с адаптер SATA->USB USB 3.0 (USB 3.1 gen1) type-a на контроллере JMS578 Нет не работает. пытаюсь восстановить.
