Котеус писал(а):
Looks like you have short circuit on 3/5v pwm IC.
Please open datasheet for pwm IC and check for short-circuit all LDOs and outputs.
3V LDO have 145K ohm (pin #3)
5V LDO have 2,8M ohm (pin #13)
First mosfet it is: PKCH2BB
Second mosfet it is: QM3058M6AC
PWM CONTROLLER it is: SN51285ARUKR
Battery charger it is: ISL9238BHRTZ-T
1 mosfet
Drain on first mosfet: 19V
Source and gate - 0,02V up to 0,65V
2 mosfet
Drain 0,02V up to 0,65V
Source and gate ~4V
pin #4 on first and second mosfet have 0,02V up to 0,65V
pin #4 on first and second mosfet have 7,3M ohm resistance to ground
