Текущее время: 21 ноя 2024, 22:48
 Заголовок сообщения: Rtx 2080ti wont boost, no Powerdraw and voltage seen in gpuz
СообщениеДобавлено: 16 июл 2021, 12:30
Hello there.
I have a currious gainward phoenix GS rtx2080ti here: After driver Update and a reboot, this card wont anymore boost, runs only AT base frequency of 1350mhz (or 300mhz on idle). LED lights is also dissabled, and i cant turn it on over expertool from gainward.
In gpuZ - i cant See any Powerdraw or voltages.
Older driver and Older and/or newer BIOS Version wont fix anything. Furmark and 3dmark runs fine (also with 1350mhz)
What can happened here, what should i check?
Posted after 3 hours 20 minutes 33 seconds:
Solved: it Was the RGB Controller in the Fan/cooling unit, this Controller blocked the databus. Controller removed, and i must then reinstall the VGA driver and After that - All works fine :)
 Заголовок сообщения: Re: Rtx 2080ti wont boost, no Powerdraw and voltage seen in gpuz
СообщениеДобавлено: 29 дек 2021, 16:29
Hi Friend you mean the controller on the card itself or on the cooler ?with my great thanks.
СообщениеДобавлено: 14 апр 2022, 08:24
Dr.rafi писал(а):
on the cooler
Yes solved the controller on the cooler thank you for your help
СообщениеДобавлено: 30 авг 2022, 17:25
Hello I have a similar problem. Colorful 2080ti with 0% TDP stuck at 1350mhz.
Can you please help?
I have a cooler that has one output cable from the card and another small pcb that splits the fans signal and LED lights.
СообщениеДобавлено: 26 янв 2024, 04:11
Same problem here. 2080Ti was dead short on 12v after shunt mod. Replaced everything i could think of, clock do not go above 1350.
Fix is confirmed by unplugging the LED or the LED controller from the board.
It may be LED's that went bad or the controller output. Either way, it works.
Reinstall driver is a must unless you plug in a different GPU and then plug 2080Ti back, Driver will reinstall automatically and problem will go away.
СообщениеДобавлено: 26 янв 2024, 23:25
Nice i watch the video
В этой теме нет новых непрочитанных сообщений. Evga 1080 Ti Unknown and missing info gpuZ
frankmnld
16 май 2021, 06:43
YunicheK Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Zotac RTX 2080ti artifacts after driver and 0 errors on MATS, No error 43, any ideas?
metobala
24 июл 2021, 07:20
Joe24 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ASUS RTX 2080ti Question for ohms? and other...
PT-AH
17 ноя 2023, 19:41
PT-AH Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 2080TI, 3 memory chips broken?
Assassin
3066
27 май 2020, 08:04
Assassin Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. rtx 2080ti не встает драйвер
neo26rus
2377
19 июн 2020, 18:44
men2k1 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 53
