Зарегистрирован: 16 мар 2024, 02:38 Наличности на руках: 21.01 Сообщения: 16 Откуда: Bulgaria Sofia
Hello,
I have Sound Blaster Live! 5.1 (SB0100) that has dead U8 chip - it should be quartz crystal oscillator NJU6333A (https://www.digchip.org/datasheets/part ... 3A-pdf.php). Do you have any suggestion what kind of replacement can be used here? Thank you in advance!
MoneyBot
Заголовок сообщения: SB Live NJU6333A replacement
MoneyBot
bantlie
Заголовок сообщения: Re: SB Live NJU6333A replacement
vladeto78
Добавлено: 19 авг 2024, 10:07
Thanks. But I cannot see the image since I still don't have rights to see the attachments Can you post a chip number, so that I can find it myself?
bantlie
