fobos писал(а):
покажите полный лог загрузки
U-Boot 2010.06-svn2926 (Nov 30 2017 - 16:47:48)
Check Flash Memory Controller v100 ... Found
SPI Nor(cs 0) ID: 0xc8 0x40 0x18
Block:64KB Chip:16MB Name:"GD25Q128"
SPI Nor total size: 16MB
Environment SPI flash initialized
In: serial
Out: serial
Err: serial
chip type hi3520dv300
DPLL:400Mhz DDR:1600Mhz
APLL:800Mhz VPLL0:162Mhz
miiphy_link,524,0
miiphy_duplex,416,0
miiphy_speed,345,0
ETH0: PHY(phyaddr=0, rgmii) link UP: DUPLEX=HALF : SPEED=10M
MAC: 9C-14-63-78-3C-F5
phy id:0xff000715
nice find PHY MARVELL6071 on higmac
hwid_gpio_val=0x1A
hwid_gpio_val=0x1A
hwid_gpio_val=0x1A
hwid_gpio_val=0x1A
hwid_gpio_val=0x1A
DDR:: 512M
Hit any key to stop autoboot: 0
usb device not found
### CRAMFS loading 'bmp_logo.bmp' to 0x81000000
BMPW:300 BMPH:113 bit:16 biSizeImage:67802 bmp_size = 67802
miiphy_link,524,3
miiphy_link,532,ff000715
miiphy_duplex,416,8
miiphy_duplex,424,ff000715
miiphy_speed,345,8
miiphy_speed,353,ff000715
ETH0: PHY(phyaddr=8, rmii) link UP: DUPLEX=FULL : SPEED=100M
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Download Filename 'ID_5A033E7PAZ4E0A6.txt'.
Download to address: 0x82000000
Downloading: T T T
Retry count exceeded; starting again
tftp receive failed ,please check net environment
### squashfs loading '/boot/uImage' to 0x82000000
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-3.10.0
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2196104 Bytes = 2.1 MiB
Load Address: 80008000
Entry Point: 80008000
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux...
LZMA data is corrupt
-- System halted
