Текущее время: 14 ноя 2024, 07:58
 Заголовок сообщения: Lenovo thinkpad T14 gen 1 Amd Ryzen Pro need EC dump
СообщениеДобавлено: 02 ноя 2024, 17:09
Platform GT 4A1-NM-C801
Please post clean EC Dump or help remove bios from attached backup.
Thanks.
 Заголовок сообщения: Re: Lenovo thinkpad T14 gen 1 Amd Ryzen Pro need EC dump
СообщениеДобавлено: 02 ноя 2024, 18:09
use this
viewtopic.php?f=294&t=136639
СообщениеДобавлено: 02 ноя 2024, 18:15
Here you go. Try this file
EC.rar
В сети
СообщениеДобавлено: 03 ноя 2024, 14:51
Thanks for your reply.
The original backup dump size is 128ko whereas the file you posted is 256ko (double).
Any new suggestion is welcome.
---------- Добавлено спустя 2 минуты 50 секунд: ----------
Doc писал(а):
use this
Thanks for the link. It's very instructive.
СообщениеДобавлено: 03 ноя 2024, 17:35
it5261VG-256 = 256kb
it5261VG-512 = 512kb
it`s very simple
what`s yours? Make the right choice in my tool ECFinder from the link above and it`ll cut EC firmware automatically from a bios dump or update
СообщениеДобавлено: 04 ноя 2024, 01:45
it`s very simple
Mine is it5261VG-512
I tried with ECFinder_0.5.1 and ECFinder_0.4.7 as well and cmd opens and closes immediately with the error message attached.
I also used Console Mode and got the error message, I attach.
Please help me to overcome this issue.
Also, I would appreciate if you could, from your side, try ECFinder with my above attached EC dump file and post the output file if any. Might be that some DLL files needed are failing in my system, though no specific error displayed.
СообщениеДобавлено: 04 ноя 2024, 02:22
here you are
main + EC
from official Lenovo T14 Gen 1 (type 20UD, 20UE)
PS no need any additional dlls - working on bare windows7x64+
СообщениеДобавлено: 04 ноя 2024, 23:54
I used ECFinder_0.4.7 and ECFinder_0.5.1 in windows 10 system and it succeeded but don't understand how to access the saved output file ? Could you please clarify the next steps, the url that opens is in russian language.
Doc писал(а):
here you are
main + EC
Many thanks for the file. I used it but unfortunately no change, superviser password is always requested. I find strange that my EC dump shows 128ko of size, before and after flashing the new dump ?
P.S As EC size is not clearly readable on the chip, I got 512ko from a schematic, I also wrote the 256ko dump posted by mainvod to no avail.
СообщениеДобавлено: 05 ноя 2024, 00:25
output file in the same directory as it's source file
funny video from Indian guy )
https://youtu.be/cP1xIN8-FNY?t=313
I think that`s how you read it, not setting manually the correct size of the EC
СообщениеДобавлено: 09 ноя 2024, 00:58
I revert. Now, I'am well doing with EcFinder after seeing the video. Thanks. It turned out that the correct size of the it5261VG chip in my case is 256kb. So I reworked out the R1BET81W.zip [7.78 MB] dump you posted on the base of 256kb and got a file of 256, whereas the original backup dump file is only 128kb how to explain that ? Is the EC chip failing, not reading the correct size of it's integrated bios ?
В этой теме нет новых непрочитанных сообщений. Thinkpad T14 Gen 1 (MB: NM-C931) need bios
ayad
26 авг 2024, 16:35
Кузьмич Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo ThinkPad T14 Gen 1
в форуме Поиск BIOS
ciorescu1588
19
3442
03 апр 2023, 13:41
ciorescu1588 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo Thinkpad T14 Gen 2 (nm-d352) Помогите определить элементов
raul-7-
04 июл 2024, 16:50
raul-7- Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ThinkPad T14 Gen 4 (Type 21HD, 21HE)_NM-E972 REV.1.0 ищу дамп
в форуме Поиск BIOS
mumbl
17 окт 2023, 01:34
Mardekai Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo ThinkPad T14 Gen4 AMD (NM-F261) Опознать шим U4=
Driu
13 сен 2024, 20:10
Driu Перейти к последнему сообщению
Сейчас этот форум просматривают: Маньяк и гости: 7
