Текущее время: 25 янв 2025, 17:57
frankmnld
Заголовок сообщения: Galax rtx 3090 Hall of Fame Добавлено: 29 ноя 2024, 13:15 |
Зарегистрирован: 18 ноя 2020, 21:12 Наличности на руках: 62.12
Сообщения: 61 Откуда: Netherlands
Good day experts. i have bought a pcb RTX 3090 galax hall of fame, pcb has 12v, 5v, 3.3v and 1.8v present,. and Nvdd, msvdd, fbvdd and pex are missing., As per the seller the pcb is fully functional yet it is not, now he insist that it will not work untill i put a gpu chip on it,. i am confused as per other brands where the pcb is fully functional with all voltages without gpu chip and vram,. Does anyone know if this specific brand has anything different that it will not raise the voltages without gpu chip..?
Thankls
frankmnld
Заголовок сообщения: Re: Galax rtx 3090 Hall of Fame Добавлено: 29 ноя 2024, 13:34 |
ruzalit писал(а): On some boards without a video chip, the voltage rises above the norm; the board cannot be turned on without a video chip, otherwise the video memory will burn out.
Ok, yes, i only see msvdd raises to 1.7v and then drops down to zero, but nvdd and fbvdd stays 0 and pex also at 0,. So..? is this behaviour normal..?
frankmnld
Заголовок сообщения: Re: Galax rtx 3090 Hall of Fame Добавлено: 29 ноя 2024, 13:48 |
ruzalit писал(а): Why take such a risk, the video chip needs to be installed, if you are afraid of damaging the working video chip, you can install a faulty one with a damaged video memory channel to check the voltages. Yes, i do not want to risk the chip, i dont have any other damaged chip,. there is no video memory on the board so that is not an issue, i just want to be sure if this behavior is normal then i can install the gpu chip on it..
ruzalit
Заголовок сообщения: Re: Galax rtx 3090 Hall of Fame Добавлено: 30 ноя 2024, 22:14 |
Зарегистрирован: 30 авг 2015, 16:47 Наличности на руках: 3,143.85
Сообщения: 1926 Откуда: Екатеринбург
Надо было проверить сначала порядок появления напряжений power sequence , 3.3v, 12v, 5v, 1,8v, nvvdd, pex_vdd, fbvdd Возможно, отвалились детали платы, неисправен DRMOS в цепи nvvdd.
