Зарегистрирован: 07 окт 2024, 23:26 Наличности на руках: 55.54 Сообщения: 64 Откуда: Brazil
hello members. this board came to me with no video output and missing A_VDDPS5 0.9V p rail. after replace UU5, A_VDDPS5 worked fine and all woltages worked, processor is warming up but board still no working. after some measurements I found ORTCX1 no working properly (I get on osciloscope 60hz instead of 32khz even after replace this oscilator) but on AX1 oscilator I get 32khz. any ideas where to dig. ty. OOOPS: when I remove RAM module and turn on the board, it does not beep alerting about no memory module detect post
Сейчас этот форум просматривают: Google [Bot] и гости: 16
