Текущее время: 26 ноя 2026, 23:21
Страница 1 из 1 [ Сообщений: 2 ] |
| Автор |
saronno76
Заголовок сообщения: RX 6600, shorted dual mos ...  Добавлено: 25 авг 2025, 14:22 |
| Я тут случайно |
Сообщения: 1 Откуда: Italy
.. hi,I bought this rx 6600 from ebay as faulty. I found one the the NCP302155 was shorted (high side mosfet). After removing it, with my surprise, gpu still works, but it seems there has been some damage to core (memory controller I think) or memory itself. Of course, probably is not fixable (I don't even replace the NCP302155 ,,, so it lacks one phase at the moment) but I wonder, just to tinkering a bit, if it's possible to mod the bios (or change configuration modding the hardware) so to exclude the damaged part.
The card works fine before adrenalin windows driver kick in.... then you got artifacts.
it's the 8g version from powercolor.
TIA
MoneyBot
Заголовок сообщения: RX 6600, shorted dual mos ... |
