crocodile70 писал(а):
У Скуби на серваке в свободном доступе - 470
Точно !. а я чет про него забыл
---------- Добавлено спустя 2 часа 43 минуты 48 секунд: ---------- Version
MODS : 470.10
System
OperatingSystem: Linux (x86_64)
Kernel : 5.9.1-gentoo-x86_64
KernelDriver : 4.00
SBIOS Version : 1205
SBIOS Date : 05/11/2018
HostName : tinylinux
Available RAM : 15687/15985 MB (Free/Size)
Sys-uuid :
HDD-Serno :
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x2420
PDI : 0x7cf8a7d38e33240a
Raw ECID : 0x00a002000000005db8d981c4
Raw ECID (GHS) : 0x4705db8d98000000008000140
ECID : SAMSUNG-SNRZPW-08_x0_y5
Device Id : _Q9sE
Revision : a1
Sub Revision : 0
Package : 40x40
NV Base : 0xf6000000
FB Base : 0xe0000000
IRQ : 11
UUID : f8917976-98d9-e3b5-b5a3-77d0636c8922
Setting Fan 1 of GPU 0 [01:00.0] to 100%
Platform : Hardware
Foundry : Samsung
Subsystem VID : 0x10de
Subsystem DID : 0x0000
Board ID : 0x035d
Project : 4735-0310
Fuse File Fmt : JSON
Display : 0x00000200 (id)
SBIOS Init : Secondary
Native Mode : 1280x1024
Memory Size : 16384 MB
FB Vendor : Samsung
RAM Protocol : GDDR6
RAM Config : 6
WARNING: WAR(2791626): 'Num Row Remaps' reporting is disabled
ROM Version : 94.03.1d.00.05
ROM Type : NVIDIA Authenticated
ROM Partner : nvidia
ROM Project ID : 1
ROM Timestamp : 2022-6-2 00:04:32
ROM Expiration : 2022-11-29 00:04:32
PState (mode) : 8 5 3 2 [0]
PState Version : 4.0
EDC : Disabled
GPC Clock : 1950.000 MHz DEFAULT
DRAM Clock : 8000.965 MHz DEFAULT
Host Clock : 1350.000 MHz NAFLL
XBar Clock : 1837.000 MHz DEFAULT
Sys Clock : 1627.000 MHz DEFAULT
Power Clock : 540.000 MHz NAFLL
NVDec Clock : 1702.000 MHz NAFLL
Display Clock : 1350.000 MHz DEFAULT
NVVDD : 1081.25 mV
GPC Mask : 0x3f (6 GPCs)
TPC Mask : [1f 1f 1f 1f 1f 1e] (29 TPCs)
FB Mask : 0x0f (4 FB Partitions)
L2 Mask : [x 3 3 3 3] (8 L2s)
L2 Slice Mask : [x ff ff ff ff] (32 L2 Slices)
PES Mask : [7 7 7 7 7 7] (18 PESes)
ROP Mask : [3 3 3 3 3 3] (12 ROPs)
FBIO Mask : 0x0f (4 FBIO Partitions)
FBIO Shift Mask: 0x00
XP Mask : 0x03 (2 3gio Pads)
Nvdec Mask : 0x01 (1 engine)
Nvenc Mask : 0x01 (1 engine)
Nvjpg Mask : 0x00 (0 engines)
Ofa Mask : 0x01 (1 engine)
PCE Mask : 0x30 (2 PCEs)
Syspipe Mask : 0x01 (1 syspipe)
Gpu Temp : 32 deg C
PEX Rx Lanes : 0x000f
PEX Tx Lanes : 0x000f
PEX Det. Lanes : 0xffff
PEX Width, ASLM: 4 lanes, Not Supported
PEX Link Speed : 8.0 Gbit/s
PEX BandWidth : 32.0 Gbit/s
ASPM, ASPM-CYA : (L0s/L1, L0s/L1)
ASPM L1SS, CYA : (Disabled, L1.1/L1.2)
LTR : Enabled
Chipset
VID : 8086 (Intel)
Chipset DID : 190F (Unknow)
Chipset ASPM : L0s/L1
Chipset LTR : Enabled
RM Version : rel/gpu_drv/r470/r470_00-289
resumehandler.js: 1
gputest.js : 1029
oqa.spc : 3
boards.js : 2
Running test(s) on GPU 0 [01:00.0] (DID: 0x2420)
Enter SetPState (test 0) Wed Oct 8 15:57:13 2025
Switched to PState 0 (0.max). Pcie Speed=8000, x4
Speed = 8.0Gb/s, expected 8.0Gb/s
UpStreamWidth = 4, expected 16
Error 020000000143 : Global.SanityCheckLink PCI Express bus error [0.000 seconds]
Exit 020000000143 : SetPState (test 0) PCI Express bus error [0.027 seconds]
Error!
Error 020000000143 : SetPState (test 0) PCI Express bus error [0.032 seconds]
Enter WfMatsBgStress (test 178) Wed Oct 8 15:57:14 2025
Enter GLStress (test 2) Wed Oct 8 15:57:14 2025
WfMatsBgStress "Post-Run" callback failed (Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated).
GPU 0 [01:00.0] RM Thermal Events: 51 new events
Type = EVENT_ID_BA_BA_W2_T1, Category = BA, Count = 51
Bps: 131.0109 GB read or written per second (13103.1525 GB in 100.016 sec)
Bps: 25.6% percent of raw FB bw (512.0618 GB per second)
Background GLStress on dev 0 completed 4628200 frames.
dev 0: GLStress 4628200 Frames, DrawPct 100.0, avg Watts 51.775, max Watts 59.666.
INPUT_SRAM avg Watts 61.400, max Watts 84.038
INPUT_FBVDD avg Watts 100.047, max Watts 102.216
INPUT_EXT12V_8PIN0 avg Watts 46.375, max Watts 54.266
OUTPUT_NVVDD avg Watts 100.283, max Watts 131.047
GLStress "Post-Run" callback failed (Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated).
GLStress POST_RUN callbacks failed.
Exit 020000002139 : GLStress (test 2) Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated [103.619 seconds]
Error!
Error 020000002139 : WfMatsBgStress_bgthread Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated [103.627 seconds]
Error 020000178139 : WfMatsBgStress (test 178) Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated [0.041 seconds]
WfMatsBgStress "Post-Cleanup" callback failed (Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated).
WfMatsBgStress POST_RUN callbacks failed.
Error 020000178139 : WfMatsBgStress (test 178) Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated [103.641 seconds]
Exit 020000178139 : WfMatsBgStress (test 178) Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated [103.645 seconds]
Error!
GPU tests completed.
Failure(s) :
LOOP TEST CODE MESSAGE
1 SetPState 020000000143 PCI Express bus error
1 >GLStress 020000002139 Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated
1 WfMatsBgStress 020000178139 Acceptable temperature limits exceeded or the thermal sensor is broken or miscalibrated
Error Code = 020000000143 (PCI Express bus error)
MODS end : Wed Oct 8 15:58:58 2025 [110.261 seconds (00:01:50.261 h:m:s)]
Что то совсем все печально. Гпу плохо?
---------- Добавлено спустя 6 минут 27 секунд: ---------- Температура реальная выше 60 врядли там есть
---------- Добавлено спустя 27 минут 52 секунды: ---------- и еще не нравится UpStreamWidth = 4, expected 16
