Текущее время: 29 ноя 2026, 16:40
 Заголовок сообщения: MSI 970 Gaming motherboard, no post, cpu fan spins, gpu fans do not
СообщениеДобавлено: 03 дек 2025, 21:05
Hello, i purchased this MSI 970 Gaming motherboard as untested, the seller just said it was taken from a pc that was part of a job lot, not much help but ive inspected the board, the front side all looks ok but i found what i think is a missing resistor on the back side beneath the cpu socket (photo included).
I would love to know what resistor it is and also what kind of heating/soldering device i would need to complete this repair because ive never done any repair work on anything this small before and only ever done standard soldering.
Any help would be much appreciated, Sid.
 Заголовок сообщения: Re: MSI 970 Gaming motherboard, no post, cpu fan spins, gpu fans do not
СообщениеДобавлено: 04 дек 2025, 00:27
There are no resistors in the photo, these are capacitors. The elements that are not soldered are not damaged, they are not provided by the factory. In your case, it is likely that the northbridge is damaged, this is a typical problem with AM3+
СообщениеДобавлено: 04 дек 2025, 01:04
thanks for your reply Pc_Nix_Info. since posting i found a photo of another board which is exactly the same, thanks for correcting me, that was a bad couple of schoolboy errors by myself. you have confirmed my suspicion that there is a worse problem which is probably unfixable with my skill set, thanks again.
В этой теме нет новых непрочитанных сообщений. ST1000M003 FW:HP13. Spins up, but is not detected
Raydel87
09 мар 2019, 22:32
mia Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ZOTAC GAMING AMP, PROBLEM FANS PWM! SOT363
PT-AH
27 ноя 2022, 13:43
PT-AH Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. EliteOne 800 G1 (HP) 511-CPU fan not detected
KlimenkoEY
13 апр 2017, 11:18
KlimenkoEY Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HIS Radeon VII Fans 16GB проверить соответствие питаний
chernovik
22 мар 2021, 21:49
mramil Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Diagnose fault with MSI GTX 970 4GD5T OC fan tachometer
MSIGamer72
06 мар 2021, 23:39
MSIGamer72 Перейти к последнему сообщению
