Текущее время: 29 ноя 2026, 16:55
 Заголовок сообщения: DHI-XVR5116H-4KL
СообщениеДобавлено: 06 дек 2025, 20:21
Как остановить загрузку DHI-XVR5116H-4KL в Putty, может есть тест поинт на плате?
System startup
U-Boot 2010.06-svn2873 (Sep 01 2017 - 19:38:10)
Check Flash Memory Controller v100 ... Found
SPI Nand ID Table Version 1.7
SPI Nand(cs 0) ID: 0xef 0xaa 0x21 Name:"W25N01GV"
Block:128KB Page:2KB Chip:128MB*1 OOB:64B ECC:4bit/512
SPI Nand total size: 128MB
In: serial
Out: serial
Err: serial
chip type hi3531a
DPLL:400Mhz DDR:1600Mhz
APLL:1100Mhz VPLL0:297Mhz
dh_flash_update_init
nand_curr_device 0
name miniboot offset 0x00000000 len 0x00040000
name updateboot offset 0x00040000 len 0x001c0000
name boot+env offset 0x00200000 len 0x00400000
name rootfs offset 0x00600000 len 0x01400000
name userfs offset 0x01a00000 len 0x01900000
name web offset 0x03300000 len 0x00f00000
name custom offset 0x04200000 len 0x00200000
name logo offset 0x04400000 len 0x00300000
name config offset 0x04700000 len 0x00a00000
name extend offset 0x05100000 len 0x02f00000
name ALL offset 0x00000000 len 0x08000000
BDB: partid = 8; addr = 0x4700000
BDB: partid = 8; addr = 0x4720000
BDB: partid = 8; addr = 0x4820000
BDB: partid = 8; addr = 0x48a0000
BDB: partid = 8; addr = 0x48e0000
BDB: partid = 8; addr = 0x4920000
BDB: partid = 8; addr = 0x4940000
BDB: partid = 8; addr = 0x49c0000
BDB: partid = 8; addr = 0x49e0000
BDB: partid = 8; addr = 0x4a20000
BDB: partid = 8; addr = 0x4ac0000
BDB: partid = 8; addr = 0x4b20000
BDB: partid = 8; addr = 0x4b40000
BDB: partid = 8; addr = 0x4b60000
BDB: partid = 8; addr = 0x4bc0000
BDB: partid = 8; addr = 0x4be0000
BDB: partid = 8; addr = 0x4c40000
BDB: partid = 8; addr = 0x4c80000
BDB: partid = 8; addr = 0x4d00000
BDB: partid = 8; addr = 0x4d60000
BDB: partid = 8; addr = 0x4dc0000
BDB: partid = 8; addr = 0x4de0000
BDB: partid = 8; addr = 0x4e60000
BDB: partid = 8; addr = 0x4ec0000
BDB: partid = 8; addr = 0x4ee0000
BDB: partid = 8; addr = 0x5020000
BDB: partid = 8; addr = 0x5040000
BDB: partid = 8; addr = 0x5060000
BDB: partid = a; addr = 0x4700000
BDB: partid = a; addr = 0x4720000
BDB: partid = a; addr = 0x4820000
BDB: partid = a; addr = 0x48a0000
BDB: partid = a; addr = 0x48e0000
BDB: partid = a; addr = 0x4920000
BDB: partid = a; addr = 0x4940000
BDB: partid = a; addr = 0x49c0000
BDB: partid = a; addr = 0x49e0000
BDB: partid = a; addr = 0x4a20000
BDB: partid = a; addr = 0x4ac0000
BDB: partid = a; addr = 0x4b20000
BDB: partid = a; addr = 0x4b40000
BDB: partid = a; addr = 0x4b60000
BDB: partid = a; addr = 0x4bc0000
BDB: partid = a; addr = 0x4be0000
BDB: partid = a; addr = 0x4c40000
BDB: partid = a; addr = 0x4c80000
BDB: partid = a; addr = 0x4d00000
BDB: partid = a; addr = 0x4d60000
BDB: partid = a; addr = 0x4dc0000
BDB: partid = a; addr = 0x4de0000
BDB: partid = a; addr = 0x4e60000
BDB: partid = a; addr = 0x4ec0000
BDB: partid = a; addr = 0x4ee0000
BDB: partid = a; addr = 0x5020000
BDB: partid = a; addr = 0x5040000
BDB: partid = a; addr = 0x5060000
Abort
phy id:0x1cc916
nice find PHY TRL8111 on higmac
phyreg0..: 0x9040
phyreg0..: 0x9040
phyreg0..: 0x1040
reset slave hi3531a
hwid_gpio_val=0x11F
hwid_gpio_val=0x11F
hwid_gpio_val=0x11F
hwid_gpio_val=0x11F
 Заголовок сообщения: Re: DHI-XVR5116H-4KL
СообщениеДобавлено: 08 дек 2025, 12:02
У вас проблема с микросхемой NAND W25N01GV, необходимо ее заменить, предварительно залив в нее прошивку, затем прописать серийник и МАС-адрес через терминал.
Останавливается загрузка "*", если что.
СообщениеДобавлено: 08 дек 2025, 22:40
При условии что проблема с микросхемой, должна останавливаться загрузка
СообщениеДобавлено: 11 дек 2025, 22:13
отключить питание регистратора, зажать клавишу *, подать питание и отпустить * после того как в терминале побегут ***********************
СообщениеДобавлено: 30 дек 2025, 19:08
не стопает, может быть что поврежденная память дает такой эффект?
СообщениеДобавлено: 30 дек 2025, 23:51
память никак не влияет на останов загрузки...проверяйте правильность подключения и качество контакта Rx на плате рега
СообщениеДобавлено: 31 дек 2025, 23:39
не поделитесь дампом для прошивки на программаторе
СообщениеДобавлено: 04 янв 2026, 20:10
дамп по серийнику, но все равно надо будет прописывать через uart серийник, мак адрес и пр.
СообщениеДобавлено: 05 янв 2026, 21:56
fobos писал(а):
дамп по серийнику
отправил в лс
СообщениеДобавлено: 06 янв 2026, 15:30
https://cloud.mail.ru/public/APNZ/tpRk3PLRM
дамп заводской со spare, поэтому в программаторе не надо включать HWECC
СообщениеДобавлено: 08 янв 2026, 00:28
fobos писал(а):
HWECC
Флешку в регистраторе заменил, прошил вашей прошивкой, серийный номер через терминал вписал и он НАКОНЕЦ-ТО он завелся и работает. Не стопало загрузку (через *) в терминале раньше из-за поврежденной памяти, в следствии и самой прошивки. Большое Вам спасибо. Вопрос решен.
ps. спасибо, что посоветовали не включать HWECC. Тему можна закрывать.
В этой теме нет новых непрочитанных сообщений. Прошивка для DHI-XVR5116H-4KL
LineStar
13 июн 2024, 20:36
fobos Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dahua DHI-XVR5116H-4KL нужен русификатор
глаз
10 окт 2025, 11:43
глаз Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dahua DHI-XVR5108HS-4KL
ococ
08 сен 2026, 22:23
В этой теме нет новых непрочитанных сообщений. Need full NAND dump - Dahua DHI-XVR5108HS-4KL (board 80176770 41_165 D1709)
mustafamadani
26 ноя 2026, 13:33
mustafamadani Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dahua DH-XVR5216AN-4KL-X не запускается
Leo_vrn
19
4730
26 июл 2026, 22:25
BahamutD Перейти к последнему сообщению
