Vusal писал(а):
Should this Micron onboard RAM be disabled? Because you wrote “original enable” in the description.
this is manufacturer strap for (
ORIGINAL/ENABLED) Micron onboard RAM
maksim-skad писал(а):
Has anyone figured out how to disable MICRON?
duddits писал(а):
id7-high
id8-low
id9-high
id10-low
id11-low
the configuration posted by duddits
DISABLES all memory types..
NM-E331 = NM-E341
works on SKhynix too
SKhynix 8GB Original Enabled:id7-low
id8-high
id9-low
id10-low
id11-high
