Текущее время: 23 июн 2024, 22:31
P.zonouz
Заголовок сообщения: Aspire 4752 (LA-6582P) restart contentiously [РЕШЕНО] Добавлено: 14 июн 2013, 20:13 |
Зарегистрирован: 01 июн 2013, 20:03 Наличности на руках: 18.07
Hi PEW71 LA-6582P , board was switched on but restart contentiously, Ampers goes to .5 and restart, it happens for several times, CPU goes very HOT, I changed KB926QF-D3, voltage on selfs was produced, but two voltage are Suspicious, PL40,PL41 are 0.77 and PL10 is 0.95. Please Help me.
_________________ Don't give up without the fight.
SashaZmei
Заголовок сообщения: Re: Aspire 4752 restart Добавлено: 16 июн 2013, 11:32 |
Зарегистрирован: 15 ноя 2012, 12:33 Наличности на руках: 1,087.65
Сообщения: 335 Откуда: Israel
After check all hardware and voltages flash THIS VERSIONS of BIOS
_________________ Where there is a will, there is a way
